faucet base plate
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DaveU, Sep 19, 2007.
  1. DaveU
    DaveU New Member
    Sep 19, 2007
    Hello,
    I have a Delta faucet that was leaking at the hot water stem - replacing the O rings fixed that problem. However, I now see that water is also leaking out from under the base plate whenever the hot or cold tap is opened. I suspect this means the faucet is shot. Could someone please confirm this before I go out and buy a new one? Thanks for your help,
    regards,
    Dave
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    There are two O-rings under the barrel of the spout.
    Turn the water off, and replace those O-rings. I use a little plumber's grease or petroleum jelly for lube on them.
    Mike
  4. DaveU
    DaveU New Member
    Sep 19, 2007
    Hi Mike,
    Thanks for your reply, however I wasn't clear about the type of faucet.
    I think you're referring to a swivel spout that is commonly used in a kitchen. What I have here is a plain jane bathroom sink faucet with separate hot and cold handles and a single fixed spout. When either hot or cold is turned on, water seeps out from under the base.
    regards,
    Dave
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    check the airater as leaking running down in side the faucet body if not
    replace it you be much happier in the long run.
  6. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    You may not have completely tightened down the stems when you replaced the seals.
    If thats not it, there's a leak inside the faucet and it's time to get a new one, they aren't too expensive.
  7. DaveU
    DaveU New Member
    Sep 19, 2007
    You may not have completely tightened down the stems when you replaced the seals. If thats not it, there's a leak inside the faucet and it's time to get a new one, they aren't too expensive.
    It must be the latter, I did sort of suspect that, so I'll just go ahead and replace it. Thanks to everyone for their suggestions.
    regards,
    Dave
  8. DaveU
    DaveU New Member
    Sep 19, 2007
    Hello cwhyu2,
    Sorry for the slow reply, I’ve been away.
    Your advice about the aerator turned out to be correct! I had a closer look, and that's where the water was coming from. I removed the aerator and guess what? – the washer was missing. I had an O ring that “almost†fit, and that helped a lot, but didn’t completely stop the leak A trip to the hardware store for a replacement and voila – problem fixed! Thanks again for your suggestion.
    Regards,
    DaveU
Similar Threads: faucet base
Plumbing Forum, Professional & DIY Advice How do you find the location of the outdoor faucet from the basement? Aug 16, 2016
Plumbing Forum, Professional & DIY Advice Kitchen sink faucet base leak Dec 13, 2013
Plumbing Forum, Professional & DIY Advice Peerless kitchen faucet leaking at base of spout!!! Jun 13, 2011
Plumbing Forum, Professional & DIY Advice Kitchen faucet comes loose at base Mar 12, 2011
Plumbing Forum, Professional & DIY Advice Loose faucet base problem Jan 25, 2010
