Faucet and valve identification help needed....
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by systemdown, Feb 15, 2008.
  1. systemdown
    systemdown New Member
    Feb 15, 2008
    Hi, I have the faucet below and am trying to replace the ceramic valve. I've been looking around for a new valve locally and on the internet and can't seem to find a perfect match. The closest one I found is made by Price Pfister #910-900 but the end of the stem is not the same (mine has 23 notches). Here's a couple of pictures, hopefully someone knows at least the brand name of this faucet. Thanks in advance. BTW, that's teflon tape on the stem....
    [​IMG]
    [​IMG]
    and this is the closest match that I've found
    [​IMG]
  2. hj
    stem
    Recount the splines. It would be rare for them to be 23. 20 or 24 are more common. The spout looks like PP, but not the handles, so I doubt that is what you have. All of the stems "look" similar until you actually place them next to each other.
  4. jimbo
    jimbo Plumber
    I agree with hj. The spout looks like the PP Bedford.>http://www.pricepfister.com/website/documents/Products/PRD_11rod_13793_1450.jpg
    But the handles are wrong. Here is a possible scenario: someone switched out the handles at some point, with genric or non-pp handles. Hence the teflon tape to try t make it fit right??
    The Bedord uses PP 910-024( cold ) and 910-025 ( hot ) ceramic stems. Your 910-100 is similar but not correct.
  5. systemdown
    Feb 15, 2008
    hj, you are correct it is 24 splines and not 23 (I verified on the cold stem). The 910-025/4 look similar but have a bump on the bottom that mine don't. Here's a picture of the bottom:
    [​IMG]
  6. systemdown
    Feb 15, 2008
    Well after searching for this stem for so long and coming up with nothing (literally hours spent looking at diagrams of different manufacturers), I decided to try the Pfister stem/valve. Not much luck, the hole size is different. The Pfister one is much smaller in diameter. I have officially given up on this faucet, and I have ordered a new one. The new one is a Kohler coralais widespread. Thanks for help.
  7. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Time for a new faucet?
Similar Threads: Faucet valve
Plumbing Forum, Professional & DIY Advice Plumbers- your preference for tub and shower valves/ faucets Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Replaced Delta 2 handle faucet cartridges now there is small leak from valve stem Oct 30, 2016
Plumbing Forum, Professional & DIY Advice Help, id this old faucet valve cartridge? Oct 10, 2016
Plumbing Forum, Professional & DIY Advice American Standard 2 knob faucet cartridge - tightening - valve open or closed? Jul 16, 2016
Plumbing Forum, Professional & DIY Advice Delta Kitchen Faucet - sprayer diverter valve Feb 27, 2016
