Farm house gutted, Plumbers weigh in
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by samoht, Nov 13, 2008.
  1. samoht
    samoht New Member
    Nov 13, 2008
    Hello,
    New member with a few questions about an essentially new plumbing system on an old farmhouse. I have submitted two pictures:
    1. FIRST FLOOR: I have a toilet located in the corner of the first floor that is difficult to get a vent to. With my current arrangement, the toilet can be vented either through the vanity or the washing machine line. The vanity has a 5 foot wet horizontal run between it and the toilet. The washing machine has a 16 inch horizontal run between it and the 3" waste line coming from the toilet. Each of these have 1/4"/foot or slightly more slope and a 2 inch vent. Is the inspector going to fuss about this wet venting? There is the main vent about 8 feet from the toilet, but from the toilet trap to the 3" horizontal line is about 32" of drop.
    2. SECOND FLOOR: I was reading that it is a good idea to wash the toilet waste line with an upstream tub or wash machine. I have the 2" tub line coming into the top of a wye laid on its side and the toilet coming into the 45 of the wye. Also there is a vent in the 2 inch line just upstream of the wye for the toilet and tub. Will this arrangement pass with the inspector? If not, what should I change. (Nothing is glued yet. The vanity will come into the top of the low heel 90 and will have a Studor on it for venting).
    Thanks for your help
    Matt
  2. samoht
    samoht New Member
    Nov 13, 2008
    And, sorry for the jack studs. The foundation is having some work done. Also, the electrical is a mess until I get the hvac ducting in.
  4. Terry
    Aug 17, 2004
    On the bottom picture, the toilet is not vented right, and neither is the tub.
    I can't see how the venting is being done on the top picture to comment.
    Please don't close this up without a plumbing inspection.
    Right now I see too many problems.
  5. samoht
    samoht New Member
    Nov 13, 2008
    For the bottom picture: I was having finding a way to put a tee or wye just after the tub trap and have the vent come up at a 45 degree angle and vent to the inside wall (same wall the tub's faucet will be on). Looking through a plumbing book, it showed a toilet vent using a 3x3x2 waste tee on its back just downstream of the toilet with a 2" street 90 to a horizontal vent running some distance to an available wall, then turning up and into the attic. Can you suggest another way of venting the tub and toilet? The toilet has a window on the wall it backs to, otherwise I would use that.
    I will take a few more pictures of the first floor to show it better.
    All help is appreciated.
    Thanks
  6. jimbo
    jimbo Plumber
    One big problem is that a vent cannot run horizontal until it is 6" higher than the fixtures it vents.
  7. samoht
    samoht New Member
    Nov 13, 2008
    Thanks for the information about the vent low vent. I would still like to be able to vent the tub into the interior wall that in which the faucet is located. I am having difficulty finding a way to do this and keep the tub trap high enough for ceiling drywall. On way would be to remove the street 90 from the trap and replace that with a 2" sanitary tee on its belly (where a trap arm would typically come in pointed down and connect to one end of the tub trap). The one end of the sanitary tee would point horizontal as the drain and the opposite end would be connected to a street 45 or 90 and serve as the vent. Would this pass code?
  8. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You can't lay a sanitary tee on it's back.
  9. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    Maybe he can drop the drain in the bottom picture to be all below the joists, then run his smaller vent lines in the joist space and if needed, through them.
    Attached is the allowable cutting and notching from our 2006 residential Code.
  10. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Tear it all back out because it's wrong, and it's going to be a problematic plumbing system. Flushing the toilet is going to suck the lavatory dry.
  11. Southern Man
    Jun 27, 2008
    North Carolina
    Methinks less drastic measures will prevail. :rolleyes:
  12. redwoodvotesoften1
    redwoodvotesoften1 New Member
    Aug 27, 2008
    Southern Man is smart i'll tell U.
    My outhouse wuz stankin reel bad n he helped me cut out a couple of moon shaped vent holz so the wind blues right threw...
    No more stank he's a magic man.
  13. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    My friend, you are obviously not too well up on plumbing code requirements. While there are several very knowledgeable folks on this forum that have pointed out some of your errors, there are still many ways to screw this job up. Like you, I'm a committed DIYer, but I subscribe to the Dirty Harry Principle that says, "A man's got to know his limitations." The trick is to recognize when you reach your limits and go for help. There are limits to how much help we can give on the forum. My advice to you is to have your drains and vents done by a real plumber. You will be time and money ahead.:)
  14. hj
    plumbing
    We have no problem advising on minor DIY repairs, but this is a major plumbing system, and as such is not a DIY project unless you know what you are doing. How a plumber would perform your questions would often depend on how he decided to do it AFTER looking at your building and the plumbing fixture placement. It is also the reason why we spend years in school to learn how to make those decisions. The second floor tub and toilet are not vented, and the vent you do have was a waste of time and material because it does nothing.
  15. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Honestly, if faced with what is there I would cut it all out and start over. Trying to re-work it is more work than it's worth.
  16. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I might reuse some of the long lengths I cut out.
  17. samoht
    samoht New Member
    Nov 13, 2008
    I made some changes and I will pay the $50 for a reinspection. Getting a plumber would put me time ahead, but money way behind. For those of you who offered help, thank you. To me, it looks like the toilet is vented through the vent in the 90 bend that goes from horizontal to vertical (the toilet being within the critical distance to the vent). All the piping is just fitted at this point, so no need to cut and scrap it.
  18. Redwood
    Dec 15, 2007
    Service Plumber
    You mean everything we see is dry fit?:eek:
  19. samoht
    samoht New Member
    Nov 13, 2008
    The plumbing inspector said to dry fit everything and get it inspected.
  20. samoht
    samoht New Member
    Nov 13, 2008
    Unless you have advice, please save your interjections for another thread. This is the "DIY advice forum". Not blowhard forum. Writing "thats wrong" or "tear it out" does not help.
  21. Redwood
    Dec 15, 2007
    Service Plumber
    The problem is that when you dry fit the connections do not seat fully. When you you cement the connections every connection is going to be between 1/2" to 1" deeper into the hub socket than when it is dry. Your pipes will be too short.
    Sorry if you don't like "Blowhard Advice" but You are messing up!
Similar Threads: Farm house
Plumbing Forum, Professional & DIY Advice Converting a wall-mounted faucet to a "back splash faucet" for a farmhouse sink May 6, 2014
Plumbing Forum, Professional & DIY Advice Two frost proof wall hydrant advise needed; Farm and House Aug 4, 2013
Plumbing Forum, Professional & DIY Advice Video: How A Farmer Shut The Fracking Supporters Up Apr 4, 2016
Plumbing Forum, Professional & DIY Advice Gas Pipeline Farm Tap in Michigan? Nov 2, 2010
Plumbing Forum, Professional & DIY Advice Farm sink drain with overflow Jul 19, 2009
