Fan Issues
Discussion in 'Electrical Forum discussion & Blog' started by statjunk, Feb 29, 2008.
  1. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    I installed a fan last night and I was pretty surprised by the installation method. This fan was different than most fans I've installed. Most will have a bracket that attaches to the ceiling junction box. You wire the fan up by hanging it from the bracket and then you push the wires into the junction box and install the fan.
    This fan has a plate that run across the face of the ceiling box thereby sealing it off. All the wiring is done below the plate. Then the motor is mounted to the plate. The wires just float above the motor housing.
    Any one else have a problem with this?
    My thoughts are if the wires were to make there way down to the motor there could be some issues.
    This is a hugger style fan made by Monte Carlo.
  2. hj
    They won't.
  4. frenchelectrican
    frenchelectrican Electrician
    Jun 16, 2007
    Master Electrician
    NE Wis / Paris France { In France now }
    Useally not much a issue with hugger fans but just keep in your mind when you make the connections keep the wires away from the motor hub [ a housing where the fan blades connected]
Similar Threads: Issues
Electrical Forum discussion & Blog Halogen flood light issues Mar 19, 2016
Electrical Forum discussion & Blog Pending Issues Jan 25, 2015
Electrical Forum discussion & Blog Moving Service Meter, supporting issues Jun 27, 2012
Electrical Forum discussion & Blog track light issues Mar 9, 2012
Electrical Forum discussion & Blog Issues with a GFI Outlet Sep 6, 2011
