Failed Soldered Joint - Best Repair Method???
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by philtrap, Aug 2, 2013.
  1. philtrap
    philtrap Member
    Jun 19, 2013
    Civil Engineer
    Long Island, NY
    Folks,
    One of the soldered tee connections I just made on a new copper heating pipe installation failed and is dripping about 1 drop per minute. I'm going to fix it, but I was wondering if it was ok to just leave and it will fix itself???? (I've don this before with small thread leaks).
    Thanks
  2. jadnashua
    Minerals may eventually plug the leak, but it may not last. Best to fix it. Keep in mind that with heating pipes, as things expand and contract, that leak might end up sucking in some air...probably not, but air inside of a heat pipe is not your friend.
  4. Terry
    Aug 17, 2004
    I would cut it out and replace it.
    I've never been lucky enough in forty years to find a self sealing solder joint.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Only one way is right. Disassemble and redo for scratch.
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Nothing fixes itself.
  7. philtrap
    philtrap Member
    Jun 19, 2013
    Civil Engineer
    Long Island, NY
    Thanks all. I took it apart and resoldered. It's all better and it took me less than 15 minutes.
  8. jadnashua
    That's the best and most reliable solution.
Similar Threads: Failed Soldered
Plumbing Forum, Professional & DIY Advice Tubmount.com? is this a failed startup or what? Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Failed Studor Vent Affecting Other Fixtures? Aug 8, 2016
Plumbing Forum, Professional & DIY Advice Failed Well Rehab Costing $1000 Jan 17, 2016
Plumbing Forum, Professional & DIY Advice Heard Noise Behind Tub. No Access to Failed Part. How Hosed Am I? Nov 29, 2015
Plumbing Forum, Professional & DIY Advice Failed PRV Aug 26, 2014
