F&W deep well jet pump replacement
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by schudaddie, Oct 5, 2013.
  1. schudaddie
    schudaddie New Member
    Oct 5, 2013
    michigan
    I'm currently trying to figure out what pump would be suitable to replace my F&W deep well jet pump (three stage, 1hp). It's date code is 76H3 and is a model C6279. It seems to work OK but due to it's age the casting is rusting and flaking off. It might have been installed in 1977 because that's when my 2" well was installed. From the paperwork from the driller the screen is set between 116' and 220' down. The fitting on the bottom of this vertical pump looks to be a single 2" pipe running horizontally out of my basement about 2' under the ground surface. F&W's website doesn't mention a 3 stage. Only 2 stage. Most of my searching online mentions a 2 pipe. I would just like to swap out my pump as my finances won't allow a new well etc. I did come across this pump (Flotec 1 HP Multi-Stage Deep-Well Jet Pump) at a reasonable price from home depot but I don't know if they are reliable etc. any info on this topic would be greatly appreciated.
    thanks for your time, schudaddie
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
  4. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    I agree with Porky
    Around here Flotec is a 6 letter word for junk
  5. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Pardon my intrusion, but I didn't want to have a new thread for the following question on Flotec and related products. The question is whether or not Pentair has maintained sufficient separation of its various pump brands, to the effect that one of their brand names still counts for as good a product as it was before acquisition. I've seen some pumps get new brand names, like the Berkeley SSHM-2 shallow-well jet pump getting a Sta-rite label and model number.
  6. schudaddie
    Oct 5, 2013
    michigan
    thanks so much for the scoop on f%#tec. sound like contacting F&W is the way to go......
    later, schudaddie
  7. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    If it is made of plastic then avoid it.
    A 2 stage F&W cast Iron pump is fine, even a cast iron flotec is fine.
    You can buy a cast iron pump from Sears, and you will be covered if you have problems. They will also send replacement parts to your house.
    Good Luck.
  8. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    Not anymore Don. At one time Sears did sell a in-house version of the MSE Sta-Rite that was good.
  9. Texas Wellman
    Feb 9, 2010
    SE Texas-Coastal
    How do you know it's a 3 stage? All the 3 stage pumps I am aware of are at least a 1.5 HP, but I am not very familiar with the F&W brand as for some reason they have very little market share here.
  10. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I think you are correct about that pump being 2 stage, not sure how it became 3.
    Sears still offer a few different brands. F&W, Wayne, Flotec to name a few.
    The Flotec 1HP 2 stage is still being sold. Runs on 120 or 240V, 12 GPM at 50PSI.
    http://www.sears.com/flotec-deep-we...M1740994214?prdNo=38&blockNo=38&blockType=G38
    Have Fun.
  11. Texas Wellman
    Feb 9, 2010
    SE Texas-Coastal
    Look again Don. That is sold by "Hardware Habitat". They are doing the same thing Amazon does. If they don't sell it they hook you up with someone who does and then take a little cut of the action.
  12. craigpump
    Apr 12, 2012
    I can just imagine taking a pump into Sears for an exchange.
    Last weeks shoe salesman wouldn't have a clue about what he was looking at.
    Buy from a REPUTABLE supplier and get better materials with fewer hassles.
  13. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    After an acquisition they usually cease production of the higher quality pump(s) when there are two or more similar products. Then they brand the lower quality pump with the names of all the companies they previously acquired. Now they have no competition, only one production facility instead of six, and six different names for many different retailers to sell the same pump. Which by the way doesn’t last as long as it used to, but there is no longer any option, so you just replace it more often.
    In the early 90’s I saw a room full of warranty pumps at Sta-Rite (now Pentair). They said there probably isn’t anything wrong with 90% of them. But Sears bought so many pumps that they didn’t question a warranty, they just handed them another pump.
  14. craigpump
    Apr 12, 2012
    That maybe true Cary, but Sears/KMart isn't the store it used to be
  15. valveman
    Mar 15, 2006
    Lubbock, Texas
    That was back when Sears was one of the only places a homeowner could buy a submersible pump. Now they sell them under many different names to all the box stores and let them cut each others throats (prices).
  16. schudaddie
    Oct 5, 2013
    michigan
    I had to contact F&W a few years ago for info on replacing the pressure switch. I gave them the date code and model number and that's what they told me. I also have a cutaway picture in my manual that looks to be a 3 stage (3 impellers) and my pump looks to have the same number but it's castings are so rusty it's hard to tell. I need to send them an email and see what they say. The guy I bought the house from had the motor replaced 4 times. In '88,'89,'91 & 93. The first time a possible lightening damage is mentioned on the receipt. Each time a 1 hp was installed. weird.... Maybe It started out as a 1.5hp. It is wired for 220v and I can read the tag on the motor as 1 hp. I'll let you know how this plays out...
    later
  17. Texas Wellman
    Feb 9, 2010
    SE Texas-Coastal
    What is the SF (service factor) of the motor? Sometimes they can rate these a little funny. For example, a Sta-Rite MSE is a "1-HP" motor but the SF is 1.65, which means that it is really a 1.5 HP motor in 1 HP guise. One good way to tell is to check the amps.
  18. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Yes, I see that is the case. They never did build their own stuff, but they did back what they sold. At a cost of course.
    If that pump is just rusty and still working, I would knock off the rust and paint it with Epoxy Enamel paint.
    The Cast Iron 1 HP that HD sells is a decent pump if it is Model # FP4432.
    Have Fun
  19. Wet_Boots
    Mar 23, 2007
    Metro NYC
    Was Sta-Rite the manufacturer of the black plastic Craftsman pump I still see a lot of?
  20. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I would doubt it.
    It is most likely Flotec's New plastic crap.
  21. Wet_Boots
    Mar 23, 2007
    Metro NYC
    It might have been Simer, if they were making plastic pumps a generation ago. Easy enough to find an image of the ubiquitous pump. One of the results has the Simer name on the same pump.
    [​IMG]
Similar Threads: deep pump
Pumps and Tanks Well Forum & Blog. Water is life. Flat or twisted cable for deep well pump Thursday at 8:25 AM
Pumps and Tanks Well Forum & Blog. Water is life. Sta rite 1hp vertical deep well pumping but not building pressure. Jan 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. How to repair Goulds deep-well pump Sep 24, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Should I Winterize my deep well pump? Aug 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Best deep pump Jul 27, 2016
