Extreme heat trapping: what next?
Discussion in 'Water Heater Forum, Tanks' started by gellfex, Jul 2, 2011.
  1. gellfex
    gellfex Member
    Jan 10, 2010
    New Jersey
    I installed an indirect WH last winter with heat trap loops, and the hot and cold feed pipes were still quite hot from the 130 deg tank even well past the loops. While the losses from the pipes were fine in winter since it just helped heat the basement where I work, in summer it's all bad. So I just installed dielectric heat trap nipple in addition, and put foam insulation around both the zone and HW pipes, but the pipes are still damn hot. What can I do next?
    Is it possible much of the heat isn't from convection but from copper conductivity? Why does there not seem to be a nonmetallic nipple to be used in place of the dielectric? Or is this the wrong direction?
    My supplier insisted that the indirect system's passive losses would be less than the gas fired WH, even though I was firing my boiler (W-M CGi) all summer instead of it taking a vacation. I hope he's right.
Similar Threads: Extreme heat
Water Heater Forum, Tanks Reducing 2 hot water heaters to 1. Today at 2:01 PM
Water Heater Forum, Tanks Water heater has no drain pan, what precautions should I take? Mar 6, 2017
Water Heater Forum, Tanks Hot Water Heater Flame Temperature Mar 4, 2017
Water Heater Forum, Tanks Whirlpool 10 year old Water Heater Mar 4, 2017
Water Heater Forum, Tanks Gas Water Heater Explosion? Mar 4, 2017
