Extra support for cast iron tub
Discussion in 'Shower & Bathtub Forum & Blog' started by rrgtmb, Mar 6, 2013.
  1. rrgtmb
    rrgtmb New Member
    Feb 26, 2013
    NJ
    I want to install a CI kohler villager (unless not recommended) in my 20+yo townhouse on the 2nd floor. Do I have to put extra support on the beams under the subfloor? Also, how long should the 2x4 for the back wall ledger be? Will a 2x4 fit for a ledger on the wall opposite of the drain?
  2. Terry
    Aug 17, 2004
    The back wall gets a 2x4 that is 60" long aprox
    No ledger board on the ends though.
    You may need to shim the apron depending on how level your floor is. All wood framed buildings are designed to carry the weight of a tub.
  4. rrgtmb
    rrgtmb New Member
    Feb 26, 2013
    NJ
    Thanks so much!!!
  5. hj
    A 2x4 may be too "thick" for the apron on the villager tub, UNLESS you bevel the edge so it will not hit the curve on the tub. I use a 1x4.
Similar Threads: Extra support
Shower & Bathtub Forum & Blog Problem fitting tub into alcove (too much extra room) Jan 15, 2017
Shower & Bathtub Forum & Blog Extracting stuck partial thermostatic cartridge sleeve due to mineral deposits Oct 5, 2016
Shower & Bathtub Forum & Blog Tub Spiggot broke off: PVC extraction? Aug 26, 2016
Shower & Bathtub Forum & Blog Stripped Screw & Broken Extractor - Shower Faucet Jul 17, 2016
Shower & Bathtub Forum & Blog stuck tub stem seat- what size screw extractor to buy Jan 22, 2013
