"extra" holes in sink?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ldmrs, Aug 18, 2005.
  1. ldmrs
    ldmrs New Member
    Aug 18, 2005
    I have a fairly new Kohler pedestal sink and it has two holes on the bottom under the bowl where water is leaking. Why are they there and why is water coming out of them? Thanks for your help.
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    holes
    what two holes?
  4. ldmrs
    ldmrs New Member
    Aug 18, 2005
    There are two holes, one on each underside of the sink basin, near the back. Water is coming out of the one on the right side.
  5. thezster
    thezster New Member
    Jul 18, 2005
    Retired young... day trade stocks - and to keep bu
    Fort Collins, Colorado
    Looked at my pedestal sink... it's got what appears to be some sort of "knockouts" on either side of the faucet water supply holes.... looks like they would leak from the overflow if the water got that high - and if they were knocked out.... Don't know what they're for..... but wonder if yours got knocked out by mistake....
  6. hj
    leaks
    The holes could be for any number of purposes, probably none that you would use them for. If they leak the sink is defective.
  7. esdguru08
    esdguru08 New Member
    Apr 27, 2014
    Colorado
    leaking at bottom of pedestal sink
    I had this same problem. The extra holes are air-vents for the overflow cavity, and/or manufacturing venting. In this cavity there is a pedestal with a hole at the top, which will allow water to overflow into the base of the sink, where these extra holes exist. What it means is that your sink is not draining quickly enough, and if the water level build-up, to be above the secondary overflow, it will drain out of the bottom holes, onto the floor. Only solution is to clean-out your p-trap, and your plunger. This problem is commonly caused by hair in the plunger, or a semi-plugged p-trap.
  8. SHR
    SHR Member
    Mar 9, 2014
    Journeyman Plumber
    Minnesota
    I call BS. hj is correct - sink is defective if water flows out on to floor. I have installed hundreds of Kohler and hundreds more of other brands of pedestal sinks and know nonsense when I read it. Whoever told esdguru08 this BS was either lying or does not have the slightest idea what they are talking about.
  9. hj
    quote; Whoever told esdguru08 this BS was either lying or does not have the slightest idea what they are talking about.
    Oh, they knew what they were talking about, it just sounds like they successfully "dazzled him with their brilliance" so they did not have to resort to "baffling him with their B.S.". As long as he did not make them replace the sink, they were successful, and everyone else made a profit on the sale of the sink, instead of having to scrap it.
Similar Threads: extra holes
Plumbing Forum, Professional & DIY Advice WH extra-circulation line? Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Extra long copper pipes Aug 19, 2016
Plumbing Forum, Professional & DIY Advice Can I use a suspended sandpoint in pond for extraction in pond 100yds away? Pump,size?sink n shower, Dec 2, 2014
Plumbing Forum, Professional & DIY Advice Torch with swirl tip worth the extra money? Mar 23, 2014
Plumbing Forum, Professional & DIY Advice Extra Pipe Off Shower Stem Apr 30, 2012
