Exterior Hose Bib question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by fatdaddy, Jul 7, 2012.
  1. fatdaddy
    fatdaddy Member
    Aug 14, 2007
    I would like to replace an exterior hose bib with a ball valve,quarter turn replacement. The replacement has male threads that would be attached to my 1/2" copper line.
    A couple of questions:
    How do I sweat the male threaded bib to the copper? Should I attach a female threaded cooper adapter to my line and just screw it on or should I sweat the threaded male brass to a female copper and then sweat it to my 1/2" copper line?
    Also,I have to install the hose bib sideways because the deck would not allow room enough to attach a hose in the normal way. Is this common practice?
    Thanks in advance.
  2. hj
    sweat on a female threaded elbow and then screw the hose faucet into it.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If this is exposed to the outside, in Connecticut it should be a frost free valve and it will not drain if turned sideways. If it is not frost free, it should have a shut off inside so the bib can drain in the winter. It can be turned as desired, but the pipe needs to have a slight downward slope.
  5. fatdaddy
    fatdaddy Member
    Aug 14, 2007
    Thanks for the quick responses.
    I do have a shut off inside and the 1/2" line does have a slight drop to it.
    I can't say that about the other faucets,but this one does and right now it is my main concern as I have a project going on.Thanks again!
Similar Threads: Exterior Hose
Plumbing Forum, Professional & DIY Advice Installing exterior water pipe for hose through basement wall Jul 22, 2006
Plumbing Forum, Professional & DIY Advice Mystery Exterior Clean Outs Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Ideas on how to Cap an exterior cast iron cleanout Aug 29, 2016
Plumbing Forum, Professional & DIY Advice Drain pipe outside of kitchen sink on exterior wall Aug 22, 2016
Plumbing Forum, Professional & DIY Advice Exterior wall water supply lines Feb 25, 2016
