Exterior Door Requirement - Numbers of Doors?
Discussion in 'Remodel Forum & Blog' started by chuck b, Feb 5, 2011.
  1. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    RE: 624 square foot northern Michigan lakeside cottage
    There are two (2) existing exterior doors to this small cottage. One faces the deck and lake, and the other faces the road and is located in the tiny kitchen.
    I would benefit from sealing off this kitchen door and including that space in the expanded kitchen. Are a minimum of two doors required in any dwelling (again, this is a small cottage)? Or are numbers of doors related to square footage - this is 625 square feet.
    Wondering if there is some sort of fire regulation addressing this. At any place in the cottage, you are no more than 20' from the lakeside door.
    Thanks.
  2. jadnashua
    Every habitable room requires two means of exit. That MIGHT be a window. The size and height of a window off the floor and the fall to the ground dictate whether it is able to be considered an exit point.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    In a single story dwelling, the bedroom window can be an egress, as described by jad.
  5. hj
    The bedroom window CAN be an egress, but it also has to meet several stringent parameters. When customers spent too much time in the "freak show" P.T. Barnum put up a sign, "This way to the egress" over the door to the outside.
  6. jimbo
    jimbo Plumber
    San Diego, CA
    I think hj was on speaking terms with PT Barnum!!!!
  7. Agu
    Agu New Member
    May 21, 2009
    Tampa, FL
    20' is a long way if 15' of that is on fire. Check code for acceptable egress windows and get creative with the remodel to expand the kitchen and still maintain a safe exit option.
Similar Threads: Exterior Door
Remodel Forum & Blog Triming Exterior Fiberglass Door Jun 13, 2011
Remodel Forum & Blog Widening an exterior door Jun 9, 2010
Remodel Forum & Blog Fiberglass exterior door paint issue Apr 7, 2008
Remodel Forum & Blog New Exterior Doors Leaking Nov 26, 2007
Remodel Forum & Blog Adding window to exterior door. Jul 30, 2007
