Extending shower drain barell
Discussion in 'Shower & Bathtub Forum & Blog' started by matty180, Sep 7, 2008.
  1. matty180
    matty180 New Member
    Sep 7, 2008
    Hi, new to the board,
    I was wondering if anybody knows where to get a extended shower drain barell. 2" ips. I need one that is about 3 inches long from the top of the drain to the end of the threads. All of the ones I have looked at are only about 2 inces in total length. Or if somebody can tell me how to extend it. It has to be a nice drain it is for a travertine shower floor.
    Thanks Matt
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    How about posting a picture of where you need to use this?
  4. matty180
    matty180 New Member
    Sep 7, 2008
    It's for a shower drain. My mud base is about 1 3/4 " thick and I ran out of adjustment. I am just looking for a longer drain barell or a way to extend the threads.
  5. jadnashua
    It doesn't sound like the pan is constructed correctly. A shower pan normally is made up of multiple layers, a preslope, liner, then setting bed, then top layer of tile. The drain would be set so the clamping layer is at the level of the preslope so that the weep holes would be in the setting bed. A setting bed wouldn't normally be that thick, allowing room for enough adjustment to become flush with nearly any normal tile used in a shower.
    Can you describe how it is constructed? If you want to read the proper construction technique, check out www.johnbridge.com. They've got numerous articles in their 'Liberry' (sic).
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Thats why I was asking for a pic...
    It definitely sounds like something isn't right.
  7. matty180
    matty180 New Member
    Sep 7, 2008
    It is constructed properly. Thin layer of thinset (to bond mix to plywood),then preslope, then felt paper, then liner, then mud. This is a no curb shower where the bathroom floor will be flush with the shower floor. The bathroom floor was rasied 3/4 " so I need some extra thread. All I am looking for is somewhere to get a longer barrell.
    thanks matt
  8. hj
    drain
    They are not generic, so what you have is probably all that is available for your drain. Now, if it were a commercial shower with a Josam, Wade, or similar housing, then there are ways to elevate it, but probably none for your drain.
  9. matty180
    matty180 New Member
    Sep 7, 2008
    isn't a 2" ips thread standard? It's a watts commericial grade drain.
    matt
  10. James_B
    James_B New Member
    Aug 12, 2008
    none for drain
  11. Redwood
    Dec 15, 2007
    Service Plumber
    Have you got a watts p/n for your drain?
  12. matty180
    matty180 New Member
    Sep 7, 2008
    Watts proline SDCP.
  13. Redwood
    Dec 15, 2007
    Service Plumber
  14. matty180
    matty180 New Member
    Sep 7, 2008
    Thread size is 2 inch ips.
Similar Threads: Extending shower
Shower & Bathtub Forum & Blog Help with extending a price pfister shower valve body... Jun 20, 2005
Shower & Bathtub Forum & Blog Need help in identifying shower faucet Yesterday at 6:36 PM
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Wednesday at 2:58 PM
Shower & Bathtub Forum & Blog Two Shower Heads, No tub. Simple Plumbing ??? Wednesday at 12:50 PM
Shower & Bathtub Forum & Blog Sterling shower panel with crack Sunday at 4:55 AM
