Extending a Waste-Supply - Lazy Option?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by brianfoley, Aug 20, 2006.
  1. brianfoley
    brianfoley New Member
    Aug 20, 2006
    Hi there,
    I'm kinda new to all this and hoping that someone may be able to prod me in the right direction. I have decided (read: my girlfriend has told me) that our kitchen sink is to be moved to where "we get the sun".
    It's a nice idea, but it means that there will be no waste pipe where the sink is to be and we have only just tiled the floor.
    Is it possible (I know it wouldn't be ideal) to leave the waste-pipe where it is and trail a pipe extension - through existing kitchen units (would only be through one) to the new location? The plan would be to come up with something like this:
    [​IMG]
    The reality of the situation, however, is a little less straight-forward, as I would like the pipe to take a few bends and was thinking about using flexible PVC pipe to keep it as close to the rear of the units as possible?
    Does this strike anyone as impossible, or breaching some particular golden rule that I may be ignorant of? Perhaps I'm missing something obvious about pressure?
    Thanks for any help
    Brian
  2. jadnashua
    Probably won't work or meet code. All sorts of crud goes down a kitchen sink. First, you would need to maintain the 1/4" per foot slope - you probably won't have enough height to do that. Second, it doesn't appear that you are going to move the vent...it would be too far away in its present position. You might get away with an aav (air-admittance-valve) instead. If you can overcome those two things, you mightget a reliable connection. A flexible line would not (as far as I understand - I'm not a pro) meet code, and would be rife for trapping crud and clogs. Getting a rigid pipe in now could be a big pain. You might do it with a few couplings - depends somewhat on how large the cabinets are. You doing new countertops? what are you goingto do with the existing hole?
    Running water new supply lines to the relocated sink should be doable.
    So, maybe...
  4. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Might be easier to move the window.
  5. hj
    drain
    The way you have it drawn and the way your text reads, you may be breaking a lot of the golden rules.
  6. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I don't know what the whole hullabaloo is about. We're talking about a sink drain, not an atomic reactor. The worst thing that can happen, is that the sink backs up.
    What I'd recommend is to pitch the drain extension at the maximum possible slope, and if you plan on using some couplings, use PVC with nuts that you can easily open in case of a clog. In order to help prevent clogs, I'd stay away from using a garbage disposal.
    Enjoy the sunshine!!:rolleyes:
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    With all due respect, you need to tell your GF that moving plumbing around is not like moving the sofa, table, and recliner around. As a novice, you would be well advised to have a plumber evaluate the problem and get the job done properly. The "Golden Rules" are not just lofty ideals that we can just overlook if it's not convienent to follow them. There are sound reasons why things have to be plumbed in a particular way.
  8. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    If it's less than 4 or 5 foot, I think, you can arm it over, without worrying about the vent. Farther than that, I would revent it back to the original vent riser, 6 inches above the flood rim. You need to use long sweeps when you turn any corners.
  9. brianfoley
    Aug 20, 2006
    Thanks, but as I understand things the slope ratio refers to the minimum necessary slope for proper drainage rather than an absolute requirement. So, if the space actually allowed for a higher gradient (which it does - about a 20 degree slope), then it should be ok?
    In respect of code - it's not an issue for me - jurisdiction issues.
    Thanks again
  10. brianfoley
    Aug 20, 2006
    It's weird how I gravitate towards the most favourable response!
    Ah seriously though...thanks everyone. The diagram was perhaps misleading and was simply to get the "idea" across rather than offer proportionate dimensions. The actual space between the waste-pipe-fixed-in-floor and the new location is quite small - probably under 5 feet.
    Plumber will be in as part of a whole new kitchen fitting exercise I reckon, but I'm just not keen on letting anyone eat into the floor...again.
  11. brianfoley
    Aug 20, 2006
    Granted. But I wasn't asking whether I could do it, but whether it could be done.
    In this country, one rarely tends to get people out to look at work who then tell you that it doesn't need to be done. So, I simply wouldn't trust someone to come out and say "ahh yeah, you need to open up the floor again...re-line the vent under the ground...I can do it for about one and a half grand". Hence me looking for advice here.
  12. hj
    drain
    You can do it anyway you want to if doing it correctly is not an issue. In fact if it is done according to your drawing, you don't even need a trap, because everytime you drain the sink the trap's seall will be siphoned out anyway, especially if you use the 20 degree slope.
  13. brianfoley
    Aug 20, 2006
    Granted. But there is more than one correct way to do many things. The very helpful feedback here has suggested a range of reasonable alteratives, rather than one formally deducible "right answer". So, it's not that "doing it correctly is not an issue", but whether "doing it correctly" really involves some of the more intricate steps outlined above - in particular with regard to the AAV (sp?).
    In my profession, for example, I could give someone two sets of "correct" ways to deal with a particular problem, but one may be more detailed and tricky than the other.
    Don't get me wrong - all this is VERY helpful.
  14. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I think it would work, but when you go to sell your house, it's going to look...how do they say it...ghetto-rigged. Throw on some duct tape--even if it serves no purpose--helps for the effect! :)
    You could install false backs in the cabinets if you wanted to hide it though.
    Much better might be to pull up those three cabinets and trench the floor under them to move it. Might create an illegal S trap though. You could probably run the supply lines in the space under the toe kicks of the cabinets--maybe drain too.
    Jason
  15. Gary Swart
    Sep 1, 2004
    Yakima WA
    You began this thread by asking for help in going the right direction on this project, but you seem to be looking for support in doing it your way even if it's wrong. Have you considered what will happen if/when you decide to sell this house? You will not pass the inspection until this is made right.
  16. Verdeboy
    Jun 12, 2006
    This forum is like going to the Doctor. I don't always do what my Doctor tells me. I hire him or her for advice. I'm ultimately in charge of my body. In fact, I usually end up throwing out the majority of the prescriptions I get. I'd probably be dead by now if I listened to them and not my own gut feelings.:eek:
  17. brianfoley
    Aug 20, 2006
    Right direction? Again, granted...but there seems to be more than one opinion on what the right direction is...I'd rather be informed than take one particular route as gospel.
    Re selling the house. You can sell a house in Dublin city for ridiculous money if it is infested with rats, smells like pee and has a tramp living in the kitchen. A kitchen with slightly odd plumbing is the LAST thing on anyone's mind when buying a house in this city let alone something a mortgage approval-inspection will care about. I bought this house for X last year - it would be sold for 1.5-1.7X this year - that's just the way Dublin this.
  18. brianfoley
    Aug 20, 2006
    Ha! Seconded...I once had to ORDER a doctor to conduct an ultrasound on me...somewhere. Turned out I needed surgery when he was adamant that it was "just a passing pain".
  19. brianfoley
    Aug 20, 2006
    Thanks...oh I'll get around the crappy look. The question was about something being possible in principle. I will ensure the plumbers / remodellers have things nice and hidden. The problem was just that no-one seemed to have even an opinion in Ireland as to whether extending a waste line was possible. It's not an issue of law, nor of re-selling, nor of looks. All that will be taken into account. It's a question about the possibility of it being done.
    Anyway...I don't know a SINGLE person / couple my age who has bought a house in this city and NOT torn out the kitchen and put in their own. Even if this little solution ends up looking terrible, it's not something anyone here would care about when buying a house and there is ALWAYS...I mean ALWAYS someone else to sell to. It always fascinates me how you can find property shows on Digital somewhere where one single bidder actually underbids the guide price and has his or her bid accepted! Amazing...In Dublin, for every city centre house, there is about 5-10 bidders kicking the crap out of each other...always. So sell on value is not an issue.
  20. hj
    possibility
    If that was all you wanted to know, then since it is water, and water will always run downhill, you can install a pipe 1,000 feet long and as long as it has downward grade it will drain. We would just tell you not to run a 1,000 foot drain line, that is all. And almost every piping question has almost as many "correct" answers as there are plumbers, especially when we cannot see the physical property. Unfortunately, there are even more incorrect ones, some that work and some that don't.
  21. Lakee911
    Aug 23, 2005
    Columbus, OH
    That'd be a big kitchen, hj! :)
Similar Threads: Extending Waste-Supply
Plumbing Forum, Professional & DIY Advice Extending cast iron drain line for pedestal sink Nov 25, 2016
Plumbing Forum, Professional & DIY Advice Moving shower drain (extending) approx. 30" - Any considerations? Sep 26, 2016
Plumbing Forum, Professional & DIY Advice Extending Riser on P-Trap on shower drain Sep 18, 2015
Plumbing Forum, Professional & DIY Advice Extending toilet drain/flange higher - how? Valve - can I move the handle? Jul 20, 2015
Plumbing Forum, Professional & DIY Advice Extending a basement drain Jul 9, 2015
