Exposed Pex in house?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dripdrip, Sep 12, 2009.
  1. dripdrip
    dripdrip New Member
    Nov 22, 2008
    NE
    Hi, I want to install some pex for baseboard heat in my house. The pex would have to be exposed in some of the rooms. (No attic or basement.) We don't really care that much about the look, but I'm worried about UV exposure. Is there some sleeve or something I can use to protect the pex? (I think insulation is otherwise unnecessary and would just add bulk.)
    Thanks,
    DD
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    paint it with latexs paint
    I think you can simply paint it with latex paint to seal off
    the pipe from the uv exposure.....
    check with the place you bought it from
  4. hj
    Uv
    Is it where the sun can shine directly on it? If not it will not have UV exposure.
  5. Ian Gills
    Jul 24, 2007
    USA
    So put it where the sun don't shine.
  6. jdgoodman
    jdgoodman Journeyman Plumber
    Sep 14, 2009
    Seattle
    Sunlight is not the only killer of pex piping. A fluorescent lamp or fluorescent tube is a gas-discharge lamp that uses electricity to excite mercury vapor. The excited mercury atoms produce short-wave ULTRAVIOLET light that then causes a phosphor to fluoresce, producing visible light. Its not much but over time it will destroy the pipe.
  7. seaofnames
    seaofnames DIY Senior Member
    Jan 25, 2009
    Boilermaker
    Mission, BC
    Does pex 'radiate' as well as copper does? You cant just have a bare pipe sitting in the covers, it has to have those little heat sinks/fins on it to radiate more efficiently.
    How hot is the water going through the pipes? Pressure and temperature determine the lifespan of all piping, so make sure it is approved for the application.
    There is UV rated pex out there.
Similar Threads: Exposed house
Plumbing Forum, Professional & DIY Advice Any issues with exposed PEX? Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Preventing freezing of an exposed section of sewage ejector discharge line... Jan 4, 2017
Plumbing Forum, Professional & DIY Advice Aesthetics: exposed heat pipe near basement ceiling Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Exposed pipes in attic - insulate attic? Oct 24, 2016
Plumbing Forum, Professional & DIY Advice Exposed copper pipe to pedestal lav Mar 7, 2014
