Explain this 3 way
Discussion in 'Electrical Forum discussion & Blog' started by DirtIsMoney, Dec 19, 2010.
  1. DirtIsMoney
    DirtIsMoney New Member
    Dec 19, 2010
    Brooklyn, NY
    I have an existing 3 way in my house that is wired like this:
    Staircase..
    My feed is in the 1st floor fixture with a 3 wire going down to the 1st floor switch.
    3 wire from 1st floor switch to 2nd floor switch.. and a 2 wire from the 2nd floor switch to the second floor fixture?? I removed switches to remodel before realizing how it was wired.. An explanation would be appreciated.
  2. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    This isn't something that should be explained over the internet.
    You shouldn't have messed with it, and now you need to hire a professional to fix it for you.
  4. jadnashua
    It can get confusing...you'll need to search some 'common' diagrams on 3-way switch installation. You'll need a meter to figure out where your hot leads are before you start to connect anything back together.
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    I don’t think this can be fixed without a toaster, hair dryer and a DVM. I am sure that that guy will be along shortly to explain all this to you.
    Two lights on two different floors wired as you have proposed is impossible.
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Each insulated wire goes to neutral, hot, a switch or the lamp. The colors will help some but with an incand. bulb, wire labels, an extension cord, clip leads and a DVM you can figure this out. But it's tedious.
  7. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    You left out the toaster and hair dryer. How can they fix this without a toaster and hair dryer?
    Colors mean a lot especially the neutral and the return leg from the switch but it can’t be done without a toaster, hair dryer, drop cord, some clips, and a DVM.
  8. hj
    3 way
    You need a voltmeter, and the knowledge of how to use it, before you can decipher which is the line, which is the load, and which are the travelers in order to make the circuit work properly. With the right knowledge, experience, and equipment, it could be done in a matter of minutes, otherwise it can be hours of frustrating hit and miss trials.
Similar Threads: Explain
Electrical Forum discussion & Blog Please Explain Small Gauges of Extension Cords Nov 7, 2012
Electrical Forum discussion & Blog This is why no one should ever get cocky when someone explains electrical Jul 5, 2012
Electrical Forum discussion & Blog Explain Out of Phase Amperage? Mar 22, 2010
Electrical Forum discussion & Blog Can someone explain what's going on in this panel? (Pic included) Feb 14, 2008
