Baumgrenze
I have 3 expansion tanks in my furnace/utility room. I recently read some threads here that explain that eventually the rubber diaphragm will fail and the tank will fill with water.
Filled with water it may break the pipe holding it unless it is otherwise supported.
My tanks are 8" in diameter by 9" and 12" in diameter by 12" so I make these ~400 cu in and 2412 cu in or 14.5 # and 87# respectively. The largest may be on 'borrowed time' since it has 'installed in 2000' written on it. The others date from the summer of 2010.
The roof over the tanks is 2x6 T&G redwood decking, so the easiest support is plumber's tape screwed to the decking and secured beneath as to a 'cradle' to hold the load.
How big a load can ordinary 3/4" wide perforated plumber's tape support. I'd assume the load will be somewhat more that a static load since the added weight will cause some movement of the tank before the support kicks in.
Thanks
baumgrenze
Thanks
baumgrenze
