Expansion tank sizing
Discussion in 'HVAC Heating & Cooling' started by rockycmt, Sep 30, 2008.
  1. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    Can you help recommend a brand/size expansion tank for my HW system.
    I currently have one but it is a large, old, steal, bladderless tank recessed in the ceiling. I need to remove it anyways cause I have to sheetrock around the boiler so I am deciding to replace it.
    I have a 4 bedroom 2000 sf cape
    Full basement
    2 bath
    http://www.watts.com/pdf/1915356.pdf
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Nope. Need to know volume and head pressure.
  4. jadnashua
    Watts has a calculator on their website you can use. You'll need to know some stats for your heating system to get it right.
  5. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    Do I only need to take into consideration the volume of my boiler or all the piping as well? If so, how do I estimate the 1' copper lengths throughout the house?
  6. jadnashua
    You need the total volume of water, since all of it can expand and contract. Volume of a cylinder is pi*r^2*length. If you get a guess at the total length of pipe, you'll be close. But, I assume those pipes run to radiators? Unless they are finned baseboard, they'll add some. If you get a good approximation, the tanks have a fair range, you should be able to properly select one. there are 231 cubic inches in a gallon.
Similar Threads: Expansion tank
HVAC Heating & Cooling Question About Expansion Tank Nov 10, 2009
HVAC Heating & Cooling expansion tank question Apr 14, 2009
HVAC Heating & Cooling Amtrol Expansion Tank for Hydronic Heating System - Creating Air Bubbles? Feb 21, 2009
HVAC Heating & Cooling Arntrol Extrol Expansion Tank Leak Feb 20, 2009
HVAC Heating & Cooling Expansion tank sizing? Jun 5, 2008
