expansion tank and back flow
Discussion in 'Water Heater Forum, Tanks' started by dpw-ct, Apr 22, 2013.
  1. dpw-ct
    dpw-ct New Member
    Feb 18, 2012
    I have this set up in my basement in a NYC condo for 10 years, I am now being told that this is a problem any thoughts on why there would be two check valves in this set up. Is it a problem . Arrows who direction of flow through check valves/back flow preventers. Supply is Cold water supply
    fyi at bottom of photo is a weil mcclain indirect water heater
  2. dpw-ct
    dpw-ct New Member
    Feb 18, 2012
    Do you think the lower check valve should be removed?
  4. jadnashua
    Assuming that expansion tank is for the potable hot water expansion...there's not supposed to be any valve of any sort between it and the cold inlet to the WH, so yes, if there's a check valve there, assuming it's working, the expansion tank is isolated, and not doing its job. An expansion tank absorbs the increased water volume when you heat water in the tank...there has to be an unobstructed path to the tank.
Similar Threads: expansion tank
Water Heater Forum, Tanks Expansion Tank, and other water heater questions.......... Jan 28, 2017
Water Heater Forum, Tanks Expansion Tank Tee Dec 25, 2016
Water Heater Forum, Tanks Question about expansion tank, PRV and BFP Aug 6, 2016
Water Heater Forum, Tanks Who's correct: The town or the plumber? Expansion tank for water heater. May 19, 2016
Water Heater Forum, Tanks Installing new Phoenix water heater, expansion tank too? Mar 12, 2016
