Expansion tank 1 or 2
Discussion in 'Water Heater Forum, Tanks' started by Kenandjoyce, Feb 15, 2013.
  1. Kenandjoyce
    Kenandjoyce New Member
    Feb 15, 2013
    California
    My home has 2 wh serviced by 1 inlet with a prv at the point where water enters the home. Each wh services half the home (ie west wh services west side and east wh services east side). Each wh has its own shut off valve. Calif plumbing code 608.2 say an expansion must be installed downstream of the prv. No other requirements except to follow manufacturers instructions. Manufacturer states same with no other requirements. Does that mean I can get by with 1 expansion tank for both wh or do I should I install 1 for each wh.
    Thanks. Ken
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If it's sized right one is all that's needed.
    John
  4. hj
    Technically, the tank is supposed to go between the heater's shutoff valve and the heater, which would mean two tanks. One tank would absorb the pressure build up iIF the valves are not turned off.
  5. Hackneyplumbing
    Hackneyplumbing Homeowner
    Jul 30, 2012
    Alabama
    Well technically the CONNECTION for the tank would need to go between the tank type water heater and the shut off valve. The physical location of the tank does not matter it just needs to be on the cold side and no stops or checks between the water heater and the expansion tank.
    Since we are being technical.
Similar Threads: Expansion tank
Water Heater Forum, Tanks Expansion Tank, and other water heater questions.......... Jan 28, 2017
Water Heater Forum, Tanks Expansion Tank Tee Dec 25, 2016
Water Heater Forum, Tanks Question about expansion tank, PRV and BFP Aug 6, 2016
Water Heater Forum, Tanks Who's correct: The town or the plumber? Expansion tank for water heater. May 19, 2016
Water Heater Forum, Tanks Installing new Phoenix water heater, expansion tank too? Mar 12, 2016
