Existing irrigation system but no backflow preventer.
Redskins-21
Virginia
I purchased a house last year that already had an irrigation system installed by the previous owner. Come to find out, this system does not have a backflow preventer installed. I am looking to install an RPZ valve type backflow but through my research have encountered conflicting information.
My house sits on a long rectangular 1 acre lot which gradually slopes down toward the road. I have read that the backflow preventer needs to be installed 6" - 12" above the highest sprinkler head. With the slope of my lot this would be about 8' in the air and looking ridiculous. I have also read that with this particular RPZ type backflow that it just needs to sit 12" off the ground where it is to be located. Which is correct?
A Vacuum breaker is placed higher than the highest head.
A reduced pressure back flow preventer does not have that limitation.
Gary Swart
Yakima, WA
There are rules about back flow prevention devices that you should make yourself aware of. These rules are strictly enforced in some places, and ignored in other areas. Basically, they should be inspected (certified) annually by a licensed inspector. Exact procedures probably vary from place to place, but as an example, my city provided the first inspection, then each spring sends a list of inspectors in our area that can provide the service. The inspector comes to the site, preforms the check, and makes what ever repairs that might be necessary. Repairs are seldom needed, and inexpensive. The inspection fee varies from inspector to inspector, but are in the range of $35 to $50. If the inspection is not performed, the city will shut the water to the property off.
If you get something that sticks a foot above the ground, you might want to cover it with a fake rock if appropriate to your landscape. Search for mock rock, artificial rock, etc.
Otherwise a shrub might hide the item.
