Hi,
We are remodeling an existing bathroom with a double sink and I would like to check to see if the previous plumbing was correct or if while doing it I should improve it.
The current setup I found when opening the wall is like this(Sorry for crude illustrations):
Now one change that does need made is a small riser for each drain connection. The new vanity is taller, and has a fixed self right where the current drain line is. So I would need to put a small riser and then drain into that. Any issues there?
Would something like this be better? Blue being the new vent, and where the riser meets the blue would be where the new sink drain ties in.
I hope that all made sense.
Appreciate any replies!
Thanks so much
Thanks so much
