I recently had an electrician install some new lines in my basement for a server rack and am doing constant monitoring of all systems including my UPS's. Here is the deal:
Recently installed:
- 1 30A 120V circuit
- 2 20A 120V circuits.
My APC battery backup is attached to the 30A circuit.
My PowerWare battery backup is attached to one of the 20A circuits.
Using SNMP I am monitoring the input/output voltage of these battery backups. I'm having the following problems:
1. Frequently the battery backup on the 30A circuit is reporting an input voltage of 126V
2. Frequently the battery backup on the 20A circuit is reporting an input voltage of 114V
Is this normal? Obviously the output voltage is controlled by the battery backup however is there a certain voltage level that I should be monitoring as a warning and critical if it gets X number to high or low?
Thanks.
JR
Recently installed:
Thanks.
JR
