emergency advice fast
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bbillcee, Mar 8, 2010.
  1. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    i had to pull out new kitchen cabinet for get at an old galvanized waste that failed....i got the galvanized nipple out of the threaded cast fitting and need to know if a male pvc adapter is acceptable and switch it to pvc oor should i do it back in galvanized?
    i have to do this right away
  2. JOHN_P
    JOHN_P New Member
    Mar 8, 2010
    Milwaukee, WI
    I'm no expert, but I've replaced all of the galvanized drains that went into the cast iron with the threaded PVC adaptors and was just glad to get rid of the corroding pipes. Everything has worked out well for years now. Well, except for that time I was replacing the last one and in taking out the galvanized pipe, it broke the whole outlet right out of the cast iron stack. But after repairing that big mistake (seems you avoided that one), I've never had a problem with the PVC into the cast iron.
  4. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Never use galvanized piping for anything in a plumbing system...potable or not!
  5. jc60618
    jc60618 DIY Junior Member
    Dec 12, 2009
    Apprentice Plumber
    Chicago
    A male adapter with teflon tape will work just fine.
  6. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    thanx all....getting the granite in tomorrow...hell of time for this to happen
  7. hj
    If the PVC is just sticking out of the wall, it is okay to do it that way. But I would use a galvanized nipple and a female brass trap adapter. If it is a sideways pipe inside the wall, the be sure to support the PVC well, otherwise the male adapter may crack off.
Similar Threads: emergency advice
Plumbing Forum, Professional & DIY Advice Emergency Floor Drain In Basement May 3, 2016
Plumbing Forum, Professional & DIY Advice Fabricating a washer pan (for emergency during washing machine leak) Jun 18, 2015
Plumbing Forum, Professional & DIY Advice Do I Have An Emergency? Feb 5, 2015
Plumbing Forum, Professional & DIY Advice Emergency Water Tank for Toilet Sep 30, 2013
Plumbing Forum, Professional & DIY Advice How to wire emergency well pump turn off? Nov 29, 2011
