Electricity power drained
batlasi
CA, US
When I use Microwave oven, the electricity power drains to 50%. When I use washing machine, the electricity cycles as washing machine cycles. When I use garbage disposal, the electricity power surcharges. I started seeing these problems very recently. What could be wrong and how do I diagnose the problem.
Jim Port
Electrical Contractor
Maryland
www.manta.com
You need to call your power company ASAP. You may have a loose connection, typically the neutral. If the power company does not find anything then it is time to call an electrician and look for a loose connection in your equipment.
Jimbo
San Diego, CA
I don't know how you are detecting power "drained" and "surcharged" but I agree with jim port that your symptoms could well be bad neutral in the house or from the pole, and this is an emergency situation. Call your electric company immediately.
batlasi
CA, US
I called the power company and they came by and determined that the transformer was wired improperly which was causing leak. after correcting the wiring, everything is working fine.
thanks for all the feedback.
