Electrical Questions
Discussion in 'Electrical Forum discussion & Blog' started by brosnt1, Sep 27, 2007.
  1. brosnt1
    brosnt1 New Member
    Feb 10, 2006
    I have a couple of question that I'm hoping someone can answer, any response will be greatly appreciated.
    1. It states in the code book that type nm ROMEX® run thru floors is to be protected by conduit for a distance of 6" above the floor. Are they talking about in an open floor outside of the stud wall? I thought ROMEX® inside a stud wall can run unprotected thru the sub floor and bottom plate.
    2. I have a 200 amp panel mounted on the wall of a garage. I cut out a 1/2" plywood board and put it around the panel. My ROMEX® (14-2, 12-2, 10-2 and 3)is coming down from the attic and I plan to fasten it to the plywood. My question is: is this an appropriate method of wiring the runs back to the panel? I guess what I'm concerned about is the unprotected ROMEX® from the ceiling to the panel, but I have seen this on other installation whether correct or not.
    Thanks
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    You will be fine coming through the bottom plate. The Sheetrock will protect it for the first six inches
    It is going to be hard getting the cables into the panel if it is covered from the top of the panel to the ceiling.
    A close read of 110.26 and you will see that from the floor to a height of six feet above the panel or to the ceiling three feet out and 30 inches side to side belongs to the panel and is not to be blocked. This requirement is all the protection that the cables coming into the panel need.
Similar Threads: Electrical Questions
Electrical Forum discussion & Blog Electrical code questions. 2005 NEC Jun 15, 2015
Electrical Forum discussion & Blog Random electrical wiring questions May 27, 2013
Electrical Forum discussion & Blog 2 electrical questions Jun 28, 2010
Electrical Forum discussion & Blog Basic electrical questions Aug 30, 2009
Electrical Forum discussion & Blog Water questions for the electrical experts!!! Mar 3, 2009
