electrical leads to water well pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by nyati, Oct 13, 2012.
  1. nyati
    nyati New Member
    Oct 13, 2012
    Eastern Washington
    i have an in-well water pump that was replaced.
    my question is regarding the electrical leads.
    will a broken lead going down the well to the pump cause the pump to shut down ?
    i know this sounds like a stupid question but i believe i was " fleeced".
    originally the well guy stated i had a broken lead in the well but couldn't fix it due to the well blocked in. when he returned days later he had a brand spanking new pump that he hurriedly installed. after he put it in and was lowering it into the well ( it almost bottomed out ) he stopped and fixed the broken wire. then when everything was completed he fused it up and it worked.
    he's telling me that broken lead had nothing to do with the functionality of pump. i say he's a liar ! what say you experts ?
    thanks,
    nyati
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Depends which lead. If it was the green protection ground, the pump could run without it.
    In many cases, the price of the pump is less than the labour component so it is not uncommon to install a new pump when the old one needs to be pulled.
  4. bcpumpguy
    bcpumpguy New Member
    Jul 27, 2012
    Langley BC
    all depends on the age of the old pump, whether or not the megohms at the motor were ok or not. Any pump 15 years and older is really on borrowed time. That said I have pulled 40 year old working pumps, those are far and few between though.
  5. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Yes, a broken wire (not a ground wire) will cause the pump not to run.
    Yes, a broken wire (not a ground wire) can cause permanent damage to a pump motor. If the pump motor is a 230volt and it is run on 115volt, it can over heat and destroy itself.
    In my opinion, putting a new pump in with old wire is asking for trouble.
  6. nyati
    nyati New Member
    Oct 13, 2012
    Eastern Washington
    thanks guys for help and info !
    i'm glad i found this site as i'm blessed with constant water problems.
    gotta get a man out to fix some problems before the snow flies and at that time i'm gonna have him locate that splice and just find out which wire it is.
    there was a few suspect actions during this repair and the company won't let me meet with the boys that applied the fix and refuses to pop the well and confirm the wire. they won't even have a face to face meeting . in 2 tele conversations with the manager i caught him and lets call one worker " honest abe " ( the companys honest worker LOL ! ) lying several times. one instance, honest abe said the other tech had ohmed out the pump before he replaced it. i was standing right there the whole time and he didn't ohm anything out with a vom or any other test equip.
  7. craigpump
    Apr 12, 2012
    Constant water problems? Something is wrong, these systems when properly installed are one of the most reliable systems you can ever have.
Similar Threads: electrical leads
Pumps and Tanks Well Forum & Blog. Water is life. Well pump electrical short? Jul 28, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Well Seal Electrical Conduit Sep 30, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Electrical disconnect inside cistern Sep 11, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Well problems since electrical storms Aug 11, 2013
Pumps and Tanks Well Forum & Blog. Water is life. help finding posts about remote electrical service panel Jun 20, 2013
