Electrical code on Busway to a water line
Discussion in 'Electrical Forum discussion & Blog' started by Randy T, Aug 15, 2007.
  1. Randy T
    Randy T Maint Mrr/electrician
    Aug 15, 2007
    Houston,TX
    Can someone tell me what the code is relating a 600v busway and the distance from a water line? The busway is not water tight.
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    There no requirements in the NEC for a distance from water lines
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    There is no specific clearance that I know of.
    Are you concerned the pipe will burst?
    Water lines do not pose any specific threats to electrical equipment. Folks are amazed when they hear there is not a ton of clearance required between water piping and electrical equipment.
  5. Randy T
    Aug 15, 2007
    Houston,TX
    Thanks for the Info, I went thru the code book & could not find anyting on this subject. We are getting ready for a Final and the ast thing I need is to create a Red Tag.
  6. hj
    code
    In that case, you should have asked the question a long time ago, not when the job is done and the inspector is walking up to the door.
  7. Randy T
    Aug 15, 2007
    Houston,TX
    I did not know the job was going to be mine until this week. I don't get much notice around here. That has been my loudest arguement about this place.:cool:
  8. BrianJohn
    BrianJohn DIY Senior Member
    Jun 22, 2007
    VA
    Speedy:
    The number ONE reason for busway failures is WATER. The number one reason burst pipes, over flow of floor drains and toilets and slop sinks overflowing.
  9. Speedy Petey
    Jun 16, 2007
    NY State, USA
    So then why is there no code required separation between pipes and bussways?
    Obviously toilets and floor drains are not a concern.
  10. BrianJohn
    Jun 22, 2007
    VA
    The NEC does not always have rules that fit all problems. In addition this would be VERY difficult to implement, making busway less than acceptable based upon the added cost of isolation. In addition moving water pipes would do minimal as when water pipes break water goes where it pleases, I have seen little contractors can do to stop it. In addition I can only tell you what I have experienced, what manufactures, insurance companies and forensics electrical engineers I work with tell me.
  11. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    The way you are thinking is that the water pipe was installed with a flaw.
    The water pipe is not installed so it will burst but instead it is installed to handle the pressure applied.
    Should it burst it would be no diffferent than installing a buss under a roof that might leak.
    Using you way of thinking I suppose that the duck would need to be installed at least one floor down in case the roof started leaking.
  12. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Pretty much my thinking as well.
Similar Threads: Electrical code
Electrical Forum discussion & Blog Is this plumbing or electrical code? Saturday at 4:57 AM
Electrical Forum discussion & Blog Electrical code questions. 2005 NEC Jun 15, 2015
Electrical Forum discussion & Blog Renovating Bathroom- Electrical Code Mar 11, 2015
Electrical Forum discussion & Blog 1985 Electrical Code, Bathroom Circuit Amperage in Georgia Oct 19, 2011
Electrical Forum discussion & Blog NC Electrical Code - 20A GFCI Circuit in bathroom Dec 20, 2009
