Electric Wire Size for Submersible Pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by lray882, Dec 5, 2011.
  1. lray882
    lray882 New Member
    May 28, 2009
    I currently have a Franklin J Class Series V Submersible Pump 1HP 15GPM 230 Volt (2 Lead Wires + Grd.) I am using 14/2 Flat Submersible Cooper Wire with ground. The pump is 190' down the well from the surface. I was told that the wire is good for 250'. After building my house the new electric service will be 75' or more from the well at the surface. Therefore, the new length for wire required will be 265'+ (exceeding 250'). Should I go with 12/2 wire from the house to the well in conduit and set a junction box (approx 75') to avoid voltage drop? I do not want to replace the wire in the well if possible. Also, is it bad practice to place the conduit and wire in the same trench with the waterline?
    Thanks in Advance
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Running #12 to the well head and #14 down the well should be fine. No problem with wire and pipe in the same ditch.
  4. lray882
    lray882 New Member
    May 28, 2009
    Thanks, valveman. I have a setup like your picture (cycle stop valve). It works great. I have moved it to the garage. It was set temporarly at the well head during construction.
Similar Threads: Electric Wire
Pumps and Tanks Well Forum & Blog. Water is life. Well pump electric wire length Jun 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. submerssible PVC pipe and electrical wire fallen down Jul 27, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Electrical service wire for well pump -help--- well & elec. Question Apr 6, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Securing wire and electrical tape Oct 11, 2006
Pumps and Tanks Well Forum & Blog. Water is life. Shed for plumbing/electric Friday at 8:51 AM
