ELECTRIC Water heater
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by KAYTEEB, Jul 24, 2007.
  1. KAYTEEB
    KAYTEEB New Member
    Jul 24, 2007
    how do you go about pulling permits for electric water heater
    can plumber pull both permits?
    for the electric
    and one for the water heater;)
  2. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    It depends upon your local jurisdiction. In my area many permits can be handled over the Internet with payment of the fees via credit card.
    Your area may require you to visit city hall, some county office or perhaps even a state office.
    Try calling the information number for your local government and asking about building, plumbing, mechanical and electrical permits. You may be able to get all permits from one source or you may need to visit several different offices.
    Some jurisdictions may allow a plumber to disconnect an old electric water heater and reconnect the new one and some may require an electrician do the electrical work. If you are replacing a gas water heater with an electric one then an electrician would be required unless the plumber also was an electrician.
    Generally (not always) a homeowner may "pull" permits IF he/she is doing the work. If the work is being done by a contractor then the contractor needs to pull the permit.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    it depends
    In our town ---Indy---
    their is no permits necessary and any Yeahoo
    can go to lowes and jsut buy a heater and install
    it himself....
    call aplumber and ask them for a price for your area
    and see if a permit is even required.
Similar Threads: ELECTRIC Water
Plumbing Forum, Professional & DIY Advice Do I need to create more of a electrical break for the hot water heater? Dec 4, 2016
Plumbing Forum, Professional & DIY Advice Electric Water heater runs out quickly Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Buying a house - water/electric turned off in November, no winterization Feb 17, 2016
Plumbing Forum, Professional & DIY Advice Electric water heater pressure relief valve into discharge tube problem *pics* Feb 12, 2016
Plumbing Forum, Professional & DIY Advice Electric ground wire between Hot and Cold copper above water heater? Jan 22, 2016
