Electric Water Heater Recommendation
Discussion in 'Water Heater Forum, Tanks' started by redrum77, Jun 15, 2011.
  1. redrum77
    redrum77 New Member
    Jun 15, 2011
    NJ
    Anybody have a recommendation for an electric hot water heater?
    I have a 50 Gallon AO Smith Pro Max that started to leak just as the warranty expired and I am hesitant to get another one. I hear Bradford White is the way to go, but I am not even sure that I can get one around here without being a contractor. I worked for a plumber for 4 years so I would be doing the job myself. I know from him to steer clear of big box stores. I am just looking for some insight as to what is a reliable brand and if I am sizing properly. Currently I am running a 50 Gallon, 1 1/2 bath house with 4 residents. Should I upgrade to a 65 Gallon? If I do decide to get a Bradford White, should I get the High Efficiency energy model? (example HE65R6DS-65)
    Any advise would be fantastic.
    Steve
  2. jadnashua
    Size depends on use patterns and points of use: how much and how long are the showers; how much time in between; would you be running the DW or WM at the same time; multiple showers at the same time; have a big tub to fill?
  4. redrum77
    redrum77 New Member
    Jun 15, 2011
    NJ
    gotcha. 20 minute showers. About an hour in between each. only one shower running at a time. big tub, but rarely gets used. no dishwasher. Sometime we use the washing machine while showering.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Bradford White would be an excellent choice. Supposedly, BW are only sold to plumbers, but I don't think that is always the case. There should be no problem finding one anywhere in the USA.
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    rheem or bradford are ok
    whatever you buy make sure it comes with the
    heavy duty Stainless steeel elements,,,
    they are basically all the same
  7. jadnashua
    There's a big difference in the gas appliances, in the burner design, the gas valve, etc. Not much in the electric...some, but not much.
  8. hj
    No matter which brand of heater you buy, if you check the supply houses which handle that brand you will find almost the same number of units which have failed during the warranty period. Electric heaters typically fail much sooner that gas ones, and I do not know of any which come with "long life" elements standard. You have to buy them and install them yourself.
Similar Threads: Electric Water
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Low amperage, lowest cost point of use electric water heater tank for low volume use? Jan 31, 2017
Water Heater Forum, Tanks Electric Water Heater Not Measuring 240V Nov 13, 2016
Water Heater Forum, Tanks Rules for electric water heater in manufactured home in Washington state Jun 3, 2016
Water Heater Forum, Tanks PEX near electric water heater Dec 25, 2015
