electric variable flow valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Tinmaniii, Oct 16, 2008.
  1. Tinmaniii
    Tinmaniii New Member
    Oct 3, 2008
    I was wondering if any plumbers have seen a variable flow electric valve.
    I have seen on or off electric valves. I would like somethng where I can choose the flow rate.
    Kinda like a dimmer switch for a light.
    any ideas?
    Done some googling without luck, but that's a needle in a haystack.
    thanks folks
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    You're not talkng about cycle stop valves are you¿
  4. hj
    valve
    The most likely item would be an electrical ball valve, similar to Conbraco, without the automatic controller that ensures that it is either fully open or fully closed.
  5. loafer
    loafer Mechanical Engineer
    Mar 5, 2008
    Mechanical Engineer
    Maine
    Electronic flow control valves are common in the hydraulic world, but I don't know how well they would work with water. I've attached a pdf file that illustrates some inexpensive ones. The high-end servo control valves cost over 2k!
    Well, I can't upload the file because it is too big... I try to get a link.
    http://www.brand-hyd.com/catalog.htm
  6. drick
    drick In the Trades
    May 16, 2008
    Unfortunately what you want won't be cheap when you find it because it will require a stepper motor to keep it in sync with the electronic control.
    Not sure what you want it for or how much granularity you need, BUT you could buy 2 irrigation control valves piped to two ball valves and have three settings; low(1 valve set 1/3 open), medium(one valve set 2/3 open), and high (both valves open). Buy a 24V transformer and a three position switch and your done for a lot less than 2K.
    Just a thought.
  7. Tinmaniii
    Oct 3, 2008
    no not a cycle stop valve, no pump involved.
  8. Tinmaniii
    Oct 3, 2008
    thanks
    Thanks all.
    Sorry to say I don't need one anymore, my wife doesn't like my idea.
    I'm re-doing my bathroom and for the bath/shower I was going to put a thermostatic valve in plus a variable volume valve so I could set the temperature for the shower and then just use the variable flow valve to turn it off and on and never have to fiddle with the temperature setting.
    Then I was had the idea of adding the variable flow valve that was electrically controlled and hidded in the wall. Then, a flick of a switch and your shower is on (switch not in shower LOL ). My wife didn't like the idea I don't know why, but she did make a good point. I would have to get out of the shower soakin wet and go over to turn the shower off, not very practical I guess. I told her I will just put it on a timer, set it for 3 minutes and then it turns off, whether your done or not LOL. She didn't go for the infrared senso to turn it off or on either. hehe.
  9. jadnashua
    No need to electronics here at all...thermostatically controlled valves typically work just like you describe - one knob or lever for temp that you can leave where you like it, and another for volume/on/off. They either use a wax cartridge or a bi-metalic strip device to set the temp.
  10. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  11. kingsotall
    Aug 17, 2008
    :eek:
    You da man with the vids! lol
    :D
  12. hj
    shower
    Now, if you had teenagers taking a shower, then an electric normally open valve on the hot water would make sense. After about 15 minutes you could shut the valve, they would get a blast of cold water, and terminate the shower.
  13. kingsotall
    Aug 17, 2008
    Yet another wise reply from these plumbing sages!
    This is making more sense to me now... :cool:
Similar Threads: electric variable
Plumbing Forum, Professional & DIY Advice Pungent smell from the electrical outlet/kitchen Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Electric conduit thru sewer line Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Do I need to create more of a electrical break for the hot water heater? Dec 4, 2016
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Electric Water heater runs out quickly Oct 1, 2016
