MarkMCM
LIvestock watering system with well pumping to a storage tank and a line pump from the storage to the field.
Storage tank is on high point of property. Line pump is 40 feet lower than storage.
I have a float valve to shut off the line pump when tank gets to half. However, if we have a failure in the field, the pump shuts off but the tank will gravity flow to empty. Big problem.
I can connect an electric valve to the relay operating the line pump. It is 1 1/2" line.
I found this in an old valveman response http://www.sprinklerwarehouse.com/Toro-NPT-Irrigation-Valve-Scrubber-p/p220s-26-08.htm
However, it is 24 volt. Everything in the pump house is 110 or 220. Do I use this with a transformer or are there better options?
I need 15 gpm flow that can shut off against 40 feet of head.
Thanks for your help.
