Electric Meter Running fast
Discussion in 'Electrical Forum discussion & Blog' started by shahnaimath, May 15, 2011.
  1. shahnaimath
    shahnaimath New Member
    May 15, 2011
    Saudi Arabia
    Hi all,
    I have an electric heater of rating 9.6Kw. Whenever it is switched ON, my electrical meter is running fast and when I switch it OFF the speed of the Electric meter returns back to normal. Y is this so.. Please help... suggest me a procedure to solve this issue by myself... Thanks in advance..
    :cool:
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Welcome to the forum
    Your meter is doing what it is supposed to do, everything is normal
  4. jimbo
    jimbo Plumber
    San Diego, CA
    10 KW is a large electric load. More watts than a central air conditioner in cooling mode, more than a clothes dryer, about the same as a stove with a four burners and the oven running!!! The speed of a meter tells you how fast the $$$$$$$$$ is being sucked out of your wallet!!!!
  5. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    So you have a HUGE electric heater and want to know why your meter is doing it's job when it is running??? This is kind of like asking "Why do I get burned when I touch a hot stove?" :p
    Seriously, as JW said, this is completely normal.
  6. hj
    The "procedure" to stop this issue is simple, DON'T turn on the heater. The meter is recording electrical usage and that heater, whatever it is, is using a LOT of it.
  7. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That has to be a joke.
    The Weather in saudi arabia is around 100 Degrees today.
    Why would the heater be on ? I would turn it off, and turn on the air conditioner, And see how fast the meter spins.
    Have a great Day.
    DonL
  8. shahnaimath
    May 15, 2011
    Saudi Arabia
    Well First of us thanks for the replies ppl ova here....
    This is not a joke for me..lol.. We had installed the similar Heaters at different locations and didn't have any complaints.
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Maybe that one is wired incorrectly, or could be operating at around 10 KW, about normal.
    You can always determine the usage by;
    The amount of energy represented by one revolution of the disc is denoted by the symbol Kh which is given in units of watt-hours per revolution. The value 7.2 is commonly seen. Using the value of Kh, one can determine their power consumption at any given time by timing the disc with a stopwatch. If the time in seconds taken by the disc to complete one revolution is t, then the power in watts is P = 3600 * Kh Divided by t in seconds. For example, if Kh = 7.2, as above, and one revolution took place in 14.4 seconds, the power is 1800 watts. This method can be used to determine the power consumption of household devices by switching them on one by one.
    Good Luck on your project.
    DonL
    P.S. That calculation is based on a 60 HZ system, Adjust the formula for your AC operating Frequency.
  10. hj
    I am guessing that at 9.6 kw the rotation of the disc might be a bit hard to time.
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Be around every 2.5 seconds, per Rev.
    I would not want the electric bill, I would use a electric blanket, Or a Fat Girl...
    DonL
  12. shahnaimath
    May 15, 2011
    Saudi Arabia
    @ DonL
    Well Thanks for superb calculation method....Can u please little elaborate on the formula how did u derive that for a 60Hz operating frequency....
    If there is incorrect wiring...How to rectify the issue?... Do we need to check the whole wiring in the house or How...? As far when we checked the current drawn by the heating element its normal and the value is as per standards.
  13. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Which voltage system do you have?
    Is it a single phase 127 volt or 220 volt?
  14. shahnaimath
    May 15, 2011
    Saudi Arabia
    220 Volt two phase.
  15. jadnashua
    Nearly 10Kw is a large load! The meter would run much faster when it is on. That's like 100 100W light bulbs all on at the same time. Often, another means of heating is less expensive, but not always. Natural gas or propane or oil in a furnace may be more ecconomical, but maybe not as neat, and then, you'd have to pay for installation and have those as energy options. Not much you can do about it other than tighten the building up to seal leaks, add insulation, and then live with the result.
  16. hj
    quote; 220 Volt two phase.
    Actually 220 volt SINGLE phase. Check the amp draw of the heater, the main lines with and without the heater, and then you will know if the wiring is correct or not.
  17. shahnaimath
    May 15, 2011
    Saudi Arabia
    @hj
    With the heater the amps is per company standard and how do we check amps without heater i.e. load?
  18. jadnashua
    If you've checked the draw (load) of the heater, and it is within specs, and you said the meter slows way down when it is off...it sounds like it is working exactly like it should. As I said, that's like having nearly 100 100W light bulbs all on at the same time...that's a lot of electricity, and you'll pay for it. Assuming it was on continuously (unlikely, but I suppose possible), that's nearly 10Kw/hr. Where I live, that would cost about $1.65/hour, $39.60/day, or $1188/month.
  19. ballvalve
    Dec 28, 2009
    northfork, california
    In Saudia Arabia, you should use the sun to preheat your water, then a 3 or 4 KW heater element on very rarely should suffice.
  20. shahnaimath
    May 15, 2011
    Saudi Arabia
    @Jad
    Thanks for the reply...As per your explanation the meter reading looks quite obvious
  21. shahnaimath
    May 15, 2011
    Saudi Arabia
    Well DonL,
    Can u please tell me how to measure Kh i.e. watts hours per revolution, as u have mentioned that it is commonly seen as 7.2. Please help.
Similar Threads: Electric Meter
Electrical Forum discussion & Blog New Electrical Service and meter for detached garage Aug 4, 2015
Electrical Forum discussion & Blog Can remote electric meter reading cause circuit breakers to trip? Apr 11, 2011
Electrical Forum discussion & Blog Electric Meter Oct 20, 2009
Electrical Forum discussion & Blog Electric Meter Feb 10, 2009
Electrical Forum discussion & Blog In-Home Electric Meters Jun 23, 2008
