electric hot water heater doesnt heat the water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lecate, Nov 4, 2007.
  1. lecate
    lecate New Member
    Nov 4, 2007
    own electric hot water heater doesnt heat the water. would that problem be a thermostat or something deeper? i have tried to reset the tank, but i dont think it worked or i didnt do it right, by just pressing the button.
    is it possible to fix it myself? i dont have much experience with hot water heaters but i have very good mechanical skils
    any advice would be greatly appreciated!
    thnx!
  2. Cass
    Cass Plumber
    Nov 12, 2005
    While it could be quite a few things it may be the lower element and / or thermostat.
    You can check the ohms on the element which should be around 13.
  4. jadnashua
    The first thing to check is that the circuit breaker isn't tripped. If you aren't comforatable with working around electricity, the rest can be dangerous. With the CB off, you can check if the heating elements are intact. If they are, then the thermostat is likely shot. Most of these parts are farily easy to replace. Depending on the age of the tank, it might be time for replacement.
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    If the W/H is 10 yrs old or more time for a replacement.
  6. hj
    heater
    The "repair" could range from resetting the circuit breaker, to repairing a major hot water leak under a concrete slab floor. They all would have the same symptoms and without being there to test the heater we cannot tell you what the problem is or how to fix it.
  7. lecate
    lecate New Member
    Nov 4, 2007
    i am very comfortable around electricity...i just dont know how to get to the parts on the tank.
    there are two covers on the tank one upper one lower...both look the same. i am not even sure which one reads the actual temp and which i can turn to turn the temp up.
    how can i get a manuel or something?
    its a hotpoint?
    thnx for the help so far!!!
  8. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    http://www.white-rodgers.com/wrdhom/common/ptech/appliance/appliance_03.htm
    You should be able to find data for your thermostats at the link above. If not exactly the same model, they will have the same functions.
    You will have to remove the both covers to check it out, and carefully pull away some insulation.
    Both controls measure temperature. The upper control turns on power to the top element when the temperature at the upper control is below the setting. If the upper temperature is high enough, then the upper control provides power to the lower control.
    The lower control applies power to the lower element if the lower temperature is less than the setting of the lower control.
    Since the lower control gets no power when the top control is ON, the two elements are never on at the same time (unless something has failed).
    Many controls have a special "overtemperature" safety element that turns off the power and must be reset by pushing a red button on the upper control.
    You need a meter to work on electrical equipment. It is almost impossible to check out controls and equipment without a meter.
Similar Threads: electric water
Plumbing Forum, Professional & DIY Advice Do I need to create more of a electrical break for the hot water heater? Dec 4, 2016
Plumbing Forum, Professional & DIY Advice Electric Water heater runs out quickly Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Buying a house - water/electric turned off in November, no winterization Feb 17, 2016
Plumbing Forum, Professional & DIY Advice Electric water heater pressure relief valve into discharge tube problem *pics* Feb 12, 2016
Plumbing Forum, Professional & DIY Advice Electric ground wire between Hot and Cold copper above water heater? Jan 22, 2016
