Electric heater control
Discussion in 'Electrical Forum discussion & Blog' started by 801Sparks, Jan 2, 2011.
  1. 801Sparks
    801Sparks New Member
    Jan 2, 2011
    Wisconsin
    My wife has an electric foot heating mat that gets a little too hot to keep her feet on. Can I use a standard electronc dimmer switch to lower the voltage to this 90 watt 120 volt resistive load, thus lowering the temp?
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    the short answer is no.
  4. 801Sparks
    Jan 2, 2011
    Wisconsin
    Could you elaborate a little? Why is the 90 watt resistive heating element any different than an incandescent light bulb? Both are resistive loads with 100% power factor right? Is there something in the electronic square wave dimmer that wouldn't function properly?
  5. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    My short answer is;
    Did it come with a dimmer? No
    Then one can’t be used on it.
    Just how do you propose installing this dimmer for this heat pad?
    No you can’t install the dimmer so it will work through the receptacle.
    Have you thought of folding a towel and placing it over the pad?
  6. 801Sparks
    Jan 2, 2011
    Wisconsin
    A Lutron makes a 300 watt plug in lamp dimmer for about $10, it has a cord and plug on it.
    No wiring would be needed, therefore no NEC violation.
    My question is; will it work.?
    I'm sorry, but I don't think putting a folded up towel on an electric heating device sounds very safe.
  7. ballvalve
    Dec 28, 2009
    northfork, california
    Since heating pads and electric blankets come with built in rheostats, you would have been better off with a foot pad with such a control built in.
    Actually, a good dog bed warmer would have worked and they have controls. I think trying the plug in rig won't harm anything.
    The towel will just get as hot as the pad, how about a piece of lattice or some sort of gridwork that would allow some air to circulate and reduce trapped heat?
    The bottom of a plastic "flat" that plants come in from the nursery comes to mind as probably laying in the backyard. "REPURPOSE"
  8. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Just do it. You obviously only want to hear the answers you want so why bother asking.
  9. ballvalve
    Dec 28, 2009
    Thats a real new york city answer. He wanted help, not insults. What is your objection to the rheostat?
  10. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    or is it an electronic dimmer????
Similar Threads: Electric heater
Electrical Forum discussion & Blog Removed Electric Hot water Heater - Breaker Filler Plate? Mar 6, 2014
Electrical Forum discussion & Blog Choosing Electric Space Heater for Emergency. Nov 13, 2013
Electrical Forum discussion & Blog Power Out From Electric Space Heater Jan 25, 2013
Electrical Forum discussion & Blog Grounding Whirlpool Tub Motor and Heater - Bonding Panel to Electric Water Heater Feb 5, 2012
Electrical Forum discussion & Blog Baseboard electric heater & switch distance from whirlpool bathtub? Jan 25, 2012
