electric furnace
Discussion in 'Boiler Forum' started by antietam, Oct 12, 2009.
  1. antietam
    antietam New Member
    Oct 12, 2009
    Plattsburgh NY
    I have an EFM electric boiler which stays on all the time even if I disconnect the thermostat. Does any know what could be causing this problem ?
    Thank you, Leaneul
  2. jadnashua
    If it is used to produce your hot water for showers, etc., then it's doing its job. if it is only for space heating, but is speced for it, same thing. Some will maintain the boiler water temp contanstly so it can produce instant heat for the house. it could be working as designed...not necessarily as efficient as it could be, but as designed.
Similar Threads: electric furnace
Boiler Forum Tubing that is the same color as electrical conduit. Jan 27, 2017
Boiler Forum Replacing electric boiler with gas. need piping help Aug 25, 2015
Boiler Forum New Home owner - needs heat - Oil and electric available DYI Sep 11, 2013
Boiler Forum Boiler pipes and electric baseboard heat Jun 5, 2013
Boiler Forum Outdoor wood water heating system wanting to convert to electric May 18, 2013
