Ejector Pump Venting/Installation
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by dstoney828, Jan 31, 2005.
  1. dstoney828
    dstoney828 New Member
    Jan 31, 2005
    I installed a Zoeller Ejector pump in my basement for my new slop sink. My question is in regards to the venting. My main stacks are not accessible in the basement. The only access to the main stack would be to connect in the attic or run an independent stack. I was hoping to wait until the spring to do this. I purchased an automatic vent which I thought would connect to the 2" vent connection on the pump and take care of the draining of my sink and stop any odors from escaping. I would assume this is not the case because with it connected, the sink does not seem to drain. Am I using the wrong application? I am a novice when it comes to drain systems.
    I was wondering if anyone had a suggestion to temporary venting this sink with the use of an auto vent or some other means for proper sink operation.
    Thank you in advance!
    Dean
  2. hj
    Aav
    Since that unit lets air into the system but not out, when you drain your sink, there is no way for the air in the system to be displaced by the water so the water cannot drain. You need to find a way to get the vent open to the atmosphere so the air can be expelled when water enters the drain system.
  4. dstoney828
    Jan 31, 2005
    Ty
    Thank you for the information. Makes total sense!
    Dean
Similar Threads: Ejector Pump
Pumps and Tanks Well Forum & Blog. Water is life. ejector pump flowing back after 1 min Aug 18, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Can convertible pump ejector be mounted with short pieces of pipe? Jun 27, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Ejector Pump running in basement after water usage on main floor May 26, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Ejector Pump Code compliance Feb 6, 2014
Pumps and Tanks Well Forum & Blog. Water is life. New Bathroom Sewage Ejector Pump/ Pit Tie In Apr 12, 2012
