Egress Window Question.
Discussion in 'Remodel Forum & Blog' started by nelsonba, Oct 27, 2007.
  1. nelsonba
    nelsonba Member
    Sep 28, 2005
    Minnesota
    I'm adding a bathroom to the 2nd floor of my house and I'm planning to steal a 3' x 2' area from the corner of a bedroom. I called the permit office to see what types of plans they need to see. They said since I was going to be modifying part of the bedroom I might have to install an egress window. This seems ridiculous since all I'm doing is basically boxing in the corner to allow more room for the bathroom.
    Currently I have two double hung windows right next to each other. I like the look of the double hung windows, but they wouldn't be big enough to pass for egress. The opening is currently 24 inches tall by 26 inches wide which meets the width and height requirements, but not the total opening requirements. Code says the opening has to be 5.7 square feet.
    Are there any options I'm not thinking of? I don't want to put in a sliding window or a crank out window because it wouldn't fit with the rest of the house. I really don't want to reframe the window opening to allow for bigger double hung windows.
    Thanks
  2. jadnashua
    Get a definitive yes or no, not a maybe, then think about it. Somebody know the national code on this? Basically it is always a good idea to have two ways out of a bedroom, and since you are changing it, that may be part of the price of admittance. They don't enforce things retroactively (you're grandfathered normally), but make a change, and the whole thing must meet current codes.
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Maybe that was said to cover the possibility you might be planning to remove or block an existing window?
    Maybe you could ask for some clarification.
  5. theelviscerator
    theelviscerator New Member
    Oct 2, 2007
    Sales
    Elkhart, IN
    On a double hung window only the bottom half counts toward egress.
    thats why a slider or casement is always your best choice for smallest window to meet code.
  6. AZ Contractor
    AZ Contractor In the Trades
    Apr 21, 2007
    Phoenix, AZ
    Where emergency escape and rescue openings are provided they shall have a sill height of not more than 44 inches above the floor
    All emergency escape and rescue openings shall have a minimum clear opening of 5.7 square feet
    The minimum net clear opening height shall be 24 inches
    The minimum net clear opening width shall be 20 inches
Similar Threads: Egress Window
Remodel Forum & Blog Egress window versus larger window Oct 11, 2016
Remodel Forum & Blog DIY egress well cover May 26, 2014
Remodel Forum & Blog Window replacement plus house settling Nov 20, 2016
Remodel Forum & Blog Choosing window types May 30, 2016
Remodel Forum & Blog (Hopefully) simple storm window question Jul 29, 2015
