? Efficacy of Using TDS to Calculate Softener Refill Time ?
Discussion in 'Water Softener Forum, Questions and Answers' started by sidmoore, Oct 5, 2013.
  1. sidmoore
    sidmoore New Member
    Aug 10, 2013
    Comanche, Texas
    You guys set me straight with regard to TDS being useless in checking water softener output (since the TDS reading of the softened water might even exceed that of the incoming hard water)...many thanks for that little piece of enlightenment (I got the great Hach 5 kit for that test, as you suggested, and really love it!).
    However, my research seems to be suggesting that, for all practical purposes, the TDS in source water can be used to calculate a softener's salt dosage requirement. How does that approach sit with you guys? And, if that isn't practical, what's the best approach to determining refill time on my Culligan Soft-Minder Twin Model 9100?
  2. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    The amount of salt used per regen will dictate the amount of capacity you will achieve. In other words, using 15 lbs of salt on a 1 cf unit will yeild 30k grain. That same cf unit using only 6 lbs of salt, will yeild 20k grains. As you can see, with the lower salt setting is more effiecent than the higher amount. Using this formula, you can set any size unit. 1 gallon of water will dissolve 3 lbs of salt. So if you are going to use 9 lbs of salt you need 3 gallons of water. All softeners have a brine flow control. A BFC of .5 will require 6 minutes of fill time (6*.5) to achieve 3 gallons of water. So in your case you need to know the size of the unit (amount of resin) and the BFC size to determine the refill time.
Similar Threads: Efficacy Using
Water Softener Forum, Questions and Answers Katalox Light regeneration using Chlorine solution Feb 17, 2017
Water Softener Forum, Questions and Answers Water Softener, Using too much salt Nov 28, 2016
Water Softener Forum, Questions and Answers Question on using IO to clean WS resin Oct 3, 2015
Water Softener Forum, Questions and Answers Doing away with green sand filter, have ? on reusing tanks Aug 11, 2015
Water Softener Forum, Questions and Answers Where to buy Big Blue *Valve-In-Head* Sediment Prefilter Housing Jan 19, 2015
