Ecowater softner
woodsmith6
centereach new york
Hey Guys!
I've had or rather got ripped off around 18 years ago when I purchased a Ecowater softener. Disassembled unit recently because i knew that my resin was shot (water flow at faucets was greatly reduced. water flow returned when unit was in bypass.) Examined media and found it to be like fine silt. Purchased new resin ( not Eco water resin! ecowater company must be government protected. Impossible to purchase parts ). Refilled resin tank 3/4 full, reassembled unit. Flushed system, ran water for a week now. NO SOFT WATER! What gives? Installed new spider gaskets lubed with silicone grease. It's almost as though water isn't passing through resin?! I set it to regenerate, brine seems to be functioning properly.
Akpsdvan
Alaska
After you refilled the media tank with the new resin and put the upper basket back into place, there should have been an O ring on top of the distributor , is it possible that the o ring is missing? broke?
That is where I would be looking.
