Ecowater 3000 series No water enters brine tank
Discussion in 'Water Softener Forum, Questions and Answers' started by RickC, Jul 30, 2010.
  1. RickC
    RickC New Member
    Jul 30, 2010
    ohio
    We have had hard water for about 1 week. I followed the troubleshooting guide and took venturi apart and cleaned it. I watched it cycle and no water entered the brine tank. Any suggestions? thanks,
    RickC
  2. Skip Wolverton
    Skip Wolverton In the Trades
    Dec 27, 2009
    Owner of SWS Systems. I work on most water treatme
    Ocala, Fl
    There is a black flow control under the venturi gasket. Sound like it is stopped up. When you put it back in, make sure the numbers are up.
  4. RickC
    RickC New Member
    Jul 30, 2010
    ohio
    I do not think that water is entering the venturi. I took it apart and made sure that the brine tube was clear. we have had trouble with this unit in the past and they removed the flow plug and it worked for about 2 yrs now its not working again.
    Rick C
  5. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    I have seen the float get stuck in the up position. Pull the float out of the brine well. The center rod should move up and down freely. If it does not, push down on the bottom part of the rod where it is flat. Put unit in a cycle and see if it fills.
  6. Some_Mich_Guy
    Some_Mich_Guy New Member
    Sep 20, 2012
    Michigan
    Further trouble-shooting...
    Hi! I have a model 3002 which had the same problem. I removed and cleaned all of the parts in the venturi assembly, confirmed water out of that valve, wasn't getting water into the brine tank. The manual suggests clearing the tubing; did that, still problem. I ended up taking apart the tube down at the valve in the the tank (removed it, took it all apart, flushed it, put it back together) and now it works.
    I hope that you got your own softener working; just thought I'd post this as a ref. for future ppl looking for help.
Similar Threads: Ecowater 3000
Water Softener Forum, Questions and Answers Ecowater 3000 R30 How does brinewell work? Oct 16, 2016
Water Softener Forum, Questions and Answers EcoWater ECR3702 Series Jan 3, 2017
Water Softener Forum, Questions and Answers ECOwater Softener Display Reset Dec 21, 2015
Water Softener Forum, Questions and Answers EcoWater ESD 2502R39 Not Regenerating May 17, 2014
Water Softener Forum, Questions and Answers water accumulating in salt tank Ecowater 3500 May 11, 2014
