DWV Layout Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by philwgreen, Jul 25, 2013.
  1. philwgreen
    philwgreen Member
    Apr 15, 2013
    Dallas, TX
    In the process of building a garage addition that has living space above. There is a single bathroom on the second story with a lav, toilet and shower. The bathoom is 12' long with the toilet and shower on opposite ends. The main stack will pass up through the wall next to the shower.
    Just getting ready to start my rough in and wanted to run my dmv diagram past everyone here. My main questions are:
    1. First off, does this diagram look correct or am I way off?
    2. There is a utility sink on the first floor, I know I can't vent it using the bathroom lav drain but can it connect to the lav vent in the attic? And can that vent tie back into the main stack or does it need its own roof penetration? In my drawing I have it going up through the roof.
    3. My toilet is roughly 12' from the main stack so I've added a vent. Would a 2" vent be sufficient for the toilet?
    Any help/feedback is appreciated.
  2. philwgreen
    philwgreen Member
    Apr 15, 2013
    Dallas, TX
    Looked back at my drawing this evening and realized I don't think I can vent the toilet coming off the horizontal. Reworked the drawing a bit and also tied the first floor lav vent in above the second story sink.
    We're under IPC here and from what I've read there doesn't seem to be a distance limitation for the toilet vent...I may be wrong about that though. However, if I did want to vent properly - would my revised drawing be the way to do it? I didn't know if there was any danger is the toilet siphoning any of the other traps.
  4. hj
    Your toilet vent is still horizontal. As long as any trap is PROPERLY vented it will not siphon.
  5. philwgreen
    philwgreen Member
    Apr 15, 2013
    Dallas, TX
    Thanks hj.
    So if my other vents are correct (i.e. my drawing) , am I ok not venting the toilet?
    If I were going to vent the toilet how do I do it so it's not horizontal?
  6. Chris B.
    Chris B. Electrician
    Feb 5, 2013
    Electrician
    Toronto, Ontario
    Use the lavatory drain as a wet vent.
  7. Chris B.
    Feb 5, 2013
    Electrician
    Toronto, Ontario
    You can tie the vents together once you are (some distance governed by whatever code you are under, say 6") above the flood level rim of the upstairs lav.
    Maybe the stack should be on the toilet side of the room.
  8. Chris B.
    Feb 5, 2013
    Electrician
    Toronto, Ontario
    Or have two, and tie them together under the garage floor.
    (This forum won't let me save edits to my posts).
Similar Threads: Layout Question
Plumbing Forum, Professional & DIY Advice Please review layout. Another wet vent question Saturday at 5:12 PM
Plumbing Forum, Professional & DIY Advice Plumbing Layout Question Jul 15, 2013
Plumbing Forum, Professional & DIY Advice Question about drain layout for basement bathroom. Apr 24, 2012
Plumbing Forum, Professional & DIY Advice Drain Waste Venting Question Layout Mar 27, 2012
Plumbing Forum, Professional & DIY Advice Another DWV layout question Mar 2, 2012
