DWV Layout Basement Bathroom - layout review
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by great white, Feb 13, 2012.
  1. great white
    great white New Member
    Dec 16, 2009
    Michigan
    We are in the planning stages of adding bathroom to basement. This new bathroom is directly below existing upstairs bathroom. House is 1 story ranch. Looking for additional opinions. Most of the plumbing contractors are saying, AAV vent for vanity and no other vents required do to close proximity to existing stack. I am also concerned about the toilet drain connecting upstream of shower and vanity. Is there a risk with flow of toilet siphoning out the traps for shower and vanity?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The existing stack has no effect on the proposed addition.
    If that is what they are telling you they are apparently are not versed in proper plumbing or the plumbing code.
    Michigan uses the International Plumbing Code (IPC)
  4. Terry
    Aug 17, 2004
    You can not use the upstairs waste stack for the downstairs bath as any sort of vent. It's the waste stack for the upstairs.
    Wet venting is only for a bathroom group on the "same" floor. That means you can using wet venting "within" the bathroom group (altogether on one floor)
    Your layout does not vent the shower,
    The lav would vent by the AAV
Similar Threads: Layout Basement
Plumbing Forum, Professional & DIY Advice Basement bath plumbing layout May 10, 2016
Plumbing Forum, Professional & DIY Advice Advice on basement bathroom layout and venting Apr 8, 2016
Plumbing Forum, Professional & DIY Advice Basement bathroom layout Jan 19, 2015
Plumbing Forum, Professional & DIY Advice need advice on adding to existing DWV layout in basement Jun 13, 2014
Plumbing Forum, Professional & DIY Advice Basement bathroom floor broke up. Does this layout work? Jan 29, 2014
