DWV Diagram
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by luthar28, Nov 26, 2012.
  1. luthar28
    luthar28 New Member
    Nov 26, 2012
    Ontario
    Of course, the wife asked if she could move the toilet 'over there'. Me, being dumb, said 'yeah, no problem'.
    Problem. I'm having a heck of a time with venting. The basement is open and unfinished. Single story. These are some of the details:
    Distance from vent stack:
    - toilet: 7 feet (3")
    - tub: 10.5 feet (1.5")
    - sink: 2 feet (1.5")
    So I'm going to need to vent the toilet and tub, correct? This is what I've put together...don't know if it's the most economical or not (doesn't seem like it). Suggestions or comments welcome -- I could be completely wrong on this.
    (Note, the 3' on the toilet is supposed to be 3" - the pipe is 7' long).
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The 2-D drawing does not help us much. If it helps, the tub can drain to the the 3" line off the WC, as long as the connection is made after the vent.
  4. Terry
    Aug 17, 2004
    The pipe on the right..........is that existing?
    Is there anything coming down from above?
    Or anything down below?
  5. luthar28
    luthar28 New Member
    Nov 26, 2012
    Ontario
    The pipe on the right is existing....everything else is simply planned.
    Nothing above or below.
  6. Terry
    Aug 17, 2004
    Then I would use the toilet vent to wet vent the tub.
    [​IMG]
  7. luthar28
    luthar28 New Member
    Nov 26, 2012
    Ontario
    Thanks. Great diagram. So you're referring to the bottom portion, correct?
  8. Terry
    Aug 17, 2004
    Yes. This gives the basic concept.
    A tub waste is 2" with a 1.5" trap arm and 1.5" vent.
    A lav can use a 1.25" trap and waste, but most small DWV pipe is 1.5"
    Back before the 60's, you would see 1-1/4" in copper DWV and galvanized.
  9. hj
    Your "concept" as drawn is correct. Now all you have to do is install it correctly, which is not always a given. I hope that 10' tub drain is NOT all 1 1/2" pipe. We do not know enough about the room's layout to tell you if it is the best, or even most economical, method.
  10. luthar28
    luthar28 New Member
    Nov 26, 2012
    Ontario
    Should I be using 2" in that 10 foot tub drain stretch?
Similar Threads: Diagram
Plumbing Forum, Professional & DIY Advice I've got some sink drainage issues; need advice/diagram to correct Jan 3, 2017
Plumbing Forum, Professional & DIY Advice Converting septic line cleanout (diagram\pic) for drain use Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Top Floor - Water Pressure, Hard Water & Water Purification Diagram Problem Feb 6, 2016
Plumbing Forum, Professional & DIY Advice Moving Toilet, Adding Shower To Toilet Drain Line - Please Check Diagram Nov 28, 2015
Plumbing Forum, Professional & DIY Advice Feedback on DWV Diagram and order of fixtures Sep 27, 2015
