DW drain routing
holtzlou
Chicago
I installed some new cabinets and forgot to notch the bottoms to route the drain like the previous cabs were done. The old drain line ran along the floor about 3', took a right hand turn, then about 2' over into sink cabinet. It then went to a high loop and into the dw tail piece.
I was hoping to be able to drop this through the floor, over to sink base, then back up into a high loop. The counter tops on on, so trying to route under the cabs is not an option.
Any info would be greatly appreciated.
thanks
Have you checked behind the drawers for depth? Sometimes there is room behind them that would allow you to drill and run a hose.
holtzlou
Chicago
Terry,
unfortunately none of the cabs have drawers. My wife does not want the hose in the cabinets. Also, the DW is on the end of a peninsula. The cabinet right next to it faces the same as DW, but the next one(corner) the doors face the opposite direction. So trying to route it through the cabs would be an adventure.
Once the drain line drops down and then back up, it makes little difference how far it drops because the line will still be full of water. is there room to run it under the countertop behide the door frames?
holtzlou
Chicago
So go up right away and them just drop down to the dw adapter at the trap. I'm at work right now, but that may work!
What is the diameter of hose I need? I going to need longer than the 6' hoses sold at Home Depot. Do you know if they sell it by the foot?
thanks
The hose from the dishwasher is 5/8"
After the air gap, it's 7/8"
You can buy hose by the foot.
