Duravit Vario Connector, how to?
Discussion in 'Toilet Forum discussions' started by ejw1224, Sep 10, 2009.
  1. ejw1224
    ejw1224 New Member
    Sep 10, 2009
    Albany, CA
    Hi everyone, I'm getting a question from my contractor and am in need of immediate response... I have bought a duravit Happy D toilet with a Vario Connector kit to connect the toilet to a wall outlet that is very close to the ground. My contractor says he never worked with a connector kit like the vario. So my question is what does he use to connect and water proof the toilet flange to the plastic connector piece? and from the plastic piece to the out? Thank you all in advance!!! I really need help!
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    It doesn't connect to a floor flange it would couple direct to a 4" pipe.
    I'm assuming you are using the 001422 Vario connecor kit.
  4. ejw1224
    ejw1224 New Member
    Sep 10, 2009
    Albany, CA
    Yes, that is exactly what i have. this is the picture of the outlet... so there is no way to extend it from the 6" high toilet flange to this outlet? could i have two angles to lower it to that level? Thanks for your help!
  5. Peanut9199
    Apr 23, 2007
    Ontario, Canada
    You need to connect to the pipe that is connected to the floor flange.
    First you need to remove the floor flange so you can connect to the waste pipe in the wall.
    If there is enough room you can connect the straight piece with the angle piece and run it down the wall.
    If not you may need to break up the floor if it runs underneathe the floor.
  6. Neotonic
    Neotonic New Member
    Oct 13, 2008
    Photographer
    Southern California or Russia
    Boy do I want a Rear outlet Toilet...
    My Avatar Tells the Brand ;)
Similar Threads: Duravit Vario
Toilet Forum discussions Duravit vario help needed Nov 3, 2015
Toilet Forum discussions duravit vario connect wall outlet toilet gook up??? not at same level? Jun 7, 2010
Toilet Forum discussions 24 Unit Toilet Purchase - Need Some Input (Toto/American Standard/Duravit/Caroma/Stealth) Feb 9, 2017
Toilet Forum discussions Duravit Starck 3 Install Dec 23, 2016
Toilet Forum discussions Duravit Starck 3 Two-Piece toilet, with pictures Sep 13, 2016
