Ductwork through crawlspace
Discussion in 'HVAC Heating & Cooling' started by billybarty, Feb 5, 2008.
  1. billybarty
    billybarty New Member
    Jun 6, 2005
    I am planning on closing in a room under my cabin and insulating it and putting all my plumbing and heating items in there. I am building on a 2 story addition for bedrooms and am concerned about the bottom level being too cold. I have a wood stove that heats the upper level and would like to keep it. So I am concerned about the 2 zones I will have and would like to know a ballpark figure on the cost of doing 2 zones. The cabin is skirted and it is insulated but the floors are very cold in the winter. If I run the ductwork through the crawlspace should I use the insulated flexible duct or regular duct that is not insulated to help keep the floor above warm? There are some pretty tight spots to run the ducting and any tips are appreciated.
  2. CrashLanding55
    CrashLanding55 HVAC Sales Rep.
    Jan 31, 2008
    HVAC Sales Rep.
    Ashtabula, Ohio
    If your crawlspace is an unconditioned space the ductwork will need to be insulated and you'll probably will still have cold floors on really cold days. If you insulate the crawlspace and make it a conditioned space, like a basement, the ductwork will not need to be insulated and your floors will be warmer. Years ago builders tended to make crawlspaces unconditioned, like an attic but rooms above a crawlspace will be warmer if a crawlspace is made a conditioned space and it doesn't communicate with the outside.
Similar Threads: Ductwork through
HVAC Heating & Cooling Furnace click on and off noise from basement to upstairs through ductwork Feb 26, 2010
HVAC Heating & Cooling Ductwork for wood burning furnace Nov 25, 2015
HVAC Heating & Cooling Modifying HVAC Ductwork Aug 12, 2014
HVAC Heating & Cooling Assembling Ductwork For Range Hood Sep 23, 2013
HVAC Heating & Cooling Bathroom Vent and Ductwork May 5, 2013
