Ducting question?
Discussion in 'HVAC Heating & Cooling' started by thunderhead, Mar 24, 2009.
  1. thunderhead
    thunderhead New Member
    Mar 7, 2009
    I recently installed an oil furnace in my garage and am now putting the plenum on. It is a top flow furnace and i am wondering if it is worth the effort to run a duct from the plenum down to the floor. Will I get that much more heat to the floor area before it rises? I know it takes a long time to get heat down low so I can work under a car. TIA
Similar Threads: Ducting question
HVAC Heating & Cooling hrv ducting question Jan 21, 2011
HVAC Heating & Cooling 555 FlexFix UL Listed Tape sealing the joints on my rigid aluminum dryer ducting Mar 24, 2015
HVAC Heating & Cooling Bathroom Fans: Best way to install ducting? Sep 21, 2010
HVAC Heating & Cooling Mini Split ducting inside walls Sep 8, 2009
HVAC Heating & Cooling DIY HVAC Ducting? Jan 18, 2008
