Ducane furnace will not light then shuts down
Discussion in 'HVAC Heating & Cooling' started by Dean M, Sep 27, 2010.
  1. Dean M
    Dean M New Member
    Jun 25, 2006
    Hello,
    I have a Ducane Furnace model # MPGA07583A. When I turn on the thermostat the exhaust fan turns on for about 25 seconds then the unit shuts down. The error code blinks 3 times then hesitates then blinks again 3 times. The igniter does not glow and the main fan does not turn on. Right before this problem the igniter would glow, the burners would ignite and the main fan would run for about 25 seconds and then the unit would shut down. The green light on the control then blinks an error code 3 times. I replaced the flame sensor and that did not work.
    Any help or ideas on what I might try next or what parts might need replacing would be greatly appreciated. Thanks in advance.
    Dean
  2. Estrogen Hostage
    Estrogen Hostage New Member
    Sep 17, 2010
    NE KS
    You need a new ignitor. The fan isn't supposed to turn on until the plenum gets warm. It's supposed to shut down the whole thing if the flame sensor doesn't detect anything after ten seconds or so. The ignitor would come on even if the gas valve was bad - so I'd say it's the ignitor.
  4. Dean M
    Dean M New Member
    Jun 25, 2006
    Thanks EH,
    I will give it a try and post the results. Do you know of a good site where I can order the part from. Everything I have looked at here locally is super expensive! Thanks again!
    Dean
    I
Similar Threads: Ducane furnace
HVAC Heating & Cooling Ducane furnace model MPGA problem Apr 12, 2013
HVAC Heating & Cooling Ducane furnace not lighting. Draft inducer or pressure switch? Oct 4, 2010
HVAC Heating & Cooling Ducane furnace still not lighting. No power where ignitor connects to smart valve. Oct 4, 2010
HVAC Heating & Cooling ducane MPGA100B4B not lighting Mar 16, 2015
HVAC Heating & Cooling Ducane burner, perhaps pilot, won't light Jan 3, 2014
