Ducane furnace model MPGA problem
Discussion in 'HVAC Heating & Cooling' started by jerry wise, Apr 12, 2013.
  1. jerry wise
    jerry wise New Member
    Apr 12, 2013
    ohio
    I am having a problem with my Ducane furnace model MPGA series I have the trouble light blinking four times for me.I have checked all my registers and filter and they are open and clean.I removed the duct work and it is all clear.When I power up the fan starts and then stops in about ten seconds and then I just get a humming sound.The furnace actually started up fully one time for about fifteen seconds.Thanks for any info you can give me
  2. jimbo
    jimbo Plumber
    San Diego, CA
    http://www.ducanehvac.com/gas_mpga-b.php
    what is your exact model number?? Seems 4 flashes is related to high limit circuit. There should be a specific wiring diagram for you unit, probably on the inside of the cover panel
  4. jerry wise
    Apr 12, 2013
    ohio
    The model of my Ducane is MPGA050B3B.The owners manual tells me that the four flashes are the high limit switch.I checked power going into it and I am getting 28.39 reading on my voltmeter.On the other side I get a reading of.316.If I put my voltmeter on both sides and apply a small amount of vaccum I can hear thswitch click inside and I get a reading of 0.01 on the ohms.Yes I do have a diagramin the book.Thanks again
  5. jerry wise
    Apr 12, 2013
    ohio
Similar Threads: Ducane furnace
HVAC Heating & Cooling Ducane furnace not lighting. Draft inducer or pressure switch? Oct 4, 2010
HVAC Heating & Cooling Ducane furnace still not lighting. No power where ignitor connects to smart valve. Oct 4, 2010
HVAC Heating & Cooling Ducane furnace will not light then shuts down Sep 27, 2010
HVAC Heating & Cooling ducane MPGA100B4B not lighting Mar 16, 2015
HVAC Heating & Cooling Ducane burner, perhaps pilot, won't light Jan 3, 2014
